Mapserver & Oracle: WMS request works, but plain mode=map request doesn't
    Bart van den Eijnden
    bartvde at XS4ALL.NL
    Wed Apr 13 11:20:44 PDT 2005
Not completely, I just realized STATUS DEFAULT is probably not what you
want for WMS (since with a WMS you can turn layers on or off, and with
status default a layer is always on). This is okay for copyright notices,
but not for most layers.
So a better solution is:
http://localhost/cgi-bin/mapserv.exe?map=c:/ms4w/Apache/htdocs/testi/testi2.map&mode=map&layers=maa
Best regards,
Bart
On Thu, 14 Apr 2005 21:03:18 +0300, Jussi Rasinmäki
<jussi.rasinmaki at HELSINKI.FI> wrote:
> Hi,
> Indeed..., problem solved.
> Thanks,
> Jussi
> ----- Original Message -----
> From: "Bart van den Eijnden" <bartvde at xs4all.nl>
> To: "Jussi Rasinmäki" <jussi.rasinmaki at helsinki.fi>;
> <MAPSERVER-USERS at lists.umn.edu>
> Sent: Wednesday, April 13, 2005 8:49 PM
> Subject: Re: [UMN_MAPSERVER-USERS] Mapserver & Oracle: WMS request works,
>> Hi,
>> Can you try defining STATUS DEFAULT at your LAYER?
>> Best regards,
>> Bart
>> On Thu, 14 Apr 2005 20:38:14 +0300, Jussi Rasinmäki
>>> Hi all,
>>> I've got a map file that uses Oracle as data source (see below)
>>> The following request produces a blank page:
>>> but this one
>>> http://localhost/cgi-bin/mapserv.exe?map=c:/ms4w/Apache/htdocs/testi/testi2.map&request=map&layers=maa&bbox=2499999,6849999,2530000,6870000&version=1.1.0&format=png&width=500&height=500
>>> returns what it is supposed to.
>>> Why?
>>> Cheers,
>>> Jussi Rasinmäki
>>> MAP
>>>   IMAGETYPE PNG
>>>   EXTENT 2499999 6849999 2530000 6870000
>>>   SIZE 400 300
>>>   IMAGECOLOR 255 255 255
>>>   PROJECTION
>>>    "init=epsg:2392"
>>>   END
>>>   # Start of LAYER
>>> EFINITIONS  ---------------------------------------------
>>>   LAYER
>>>     NAME maa
>>>     TYPE POLYGON
>>>     CONNECTIONTYPE ORACLESPATIAL
>>>     CONNECTION "usr/psw at sid"
>>>     DATA "GEOLOC FROM MAA USING SRID 294913"
>>>     DUMP TRUE
>>>     CLASS
>>>      OUTLINECOLOR 0 0 0
>>>      COLOR 0 128 128
>>>     END
>>>     PROJECTION
>>>       "init=epsg:2392"
>>>     END
>>>   END # Maa polygon layer ends here
>>>   # End of LAYER DEFINITIONS -------------------------------
>>> END # end of map file/object
>> Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
More information about the MapServer-users
