dynamic point generation with php-mapscript
Jeff Portwine
jdport at VERITIME.COM
Fri Apr 15 06:27:24 PDT 2005
I am doing something like this in my code, except I'm using a postgres
database. My table has the longitudes and latitudes of the points. I
read in the coordinates from the postgres table, project the point into the
map projection and plot them. I cannot do map queries as you said, but I
work around that by making the map image a client side image map and make
the points clickable. This makes navigating the map trickier... I can't
use the same interface that most of the mapserver apps i've looked at use...
but it is working ok. I'm almost done with the application now on a
funcitionality level and then I'll be working on the interface because right
now it is actually pretty slow to use.
-Jeff
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Friday, April 15, 2005 7:06 AM
Subject: Re: [UMN_MAPSERVER-USERS] dynamic point generation with
php-mapscript
> Wouter Schaubroeck wrote:
>> Hi,
>> I was wondering if anyone would know some good examples of generating
>> dynamic points with php mapscript? For example: just pulling the points
>> from (in my case: a MySQL db) a database and displaying them without a
>> shape file? And is it possible to do queries on that layer, or
>> displaying the attribute data? I assume not, because there's no
>> associated dbf file.
>> Best regards,
>> Wouter Schaubroeck
> See the PHP/Mapscript WIKI - which has such an example:
> http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptAddPoint
> Querying that layer is more problematic. You need to create a shapeObj
> and addFeature()'s to that shapeObj etc:
> http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PerlMapScriptExamples42ex1
> shows you how to do this with Perl which is easily translated to PHP (I
> did it yesterday but my code is in a mess of other trial stuff just
> now), with one major exception! PHP/Mapscript is broken at the moment
> and you can't set the index of a shapeObj added to a layer (it needs to
> be numeric, integer, incrementing in steps of 1 - so not a arbitrary
> ordering of ID's from a mysql table index, currently it returns -1
> error), which you need to have queryByPoint do anything useful etc. See:
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=806
> A patch has been accepted for this bug so you can download a nightly or
> the cvs of mapserver (or replace php_mapscript.c in the tarball of
> mapserver4.4.2 with the one in that bug report) and roll your own
> php_mapscript.so.
> After a few errors I have just gotten this compiling as well (a
> nightly), so maybe I can query that layer after all... :-)
> Please note - I'm a mapserver virgin so I've been bumbling through this
> for only a day or so - feel free to email me further about this but I
> can't guarantee I'll be able to help much beyond providing some very
> early php code.
> G
> Gavin Simpson [T] +44 (0)20 7679 5522
> ENSIS Research Fellow [F] +44 (0)20 7679 7565
> ENSIS Ltd. & ECRC [E] gavin.simpsonATNOSPAMucl.ac.uk
> UCL Department of Geography [W] http://www.ucl.ac.uk/~ucfagls/cv/
> 26 Bedford Way [W] http://www.ucl.ac.uk/~ucfagls/
> London. WC1H 0AP.
More information about the MapServer-users
