dynamic point generation with php-mapscript
    Wouter Schaubroeck
    wouter.schaubroeck at GMAIL.COM
    Fri Apr 15 08:11:04 PDT 2005
Actually, I have a way to get my points out of my database. I create
dynamically a shape file with the coordinates i get from my db. And
then, i write the attributes in the dbf file. They only thing i have to
do next is to create a layer dynamically, where the shape file is being
used. This goes well, but it could go faster, if the server didn't have
to create the shapefile all the time.
best regards
Wouter Schaubroeck
Dan Taylor wrote:
>This is how I do it.  Very basic though...
>function addpoints($map, $name, $points, $r, $g, $b, $symbol,
>$font_face, $font_size)
>  // Create a layer
>  $layer = ms_newLayerObj($map);
>  $layer->set("type", MS_LAYER_POINT);
>  $layer->set("name", $name);
>  $layer->set("status", MS_ON);
>  // Create the default class and set up label
>  $cl = ms_newClassObj($layer);
>  $cl->set("status", MS_ON);
>  $cl->label->set("size", $font_size);
>  $cl->label->set("type", "MS_TRUETYPE");
>  $cl->label->set("font", $font_face);
>  $cl->label->set("position", MS_LC);
>  $cl->label->color->setRGB($r, $g, $b);
>  $cl->label->outlinecolor->setRGB(0, 0, 0);
>  // Create and set up style
>  $sty = ms_newStyleObj($cl);
>  $sty->set("symbolname", $symbol);
>  $sty->color->setRGB($r, $g, $b);
>  $sty->outlinecolor->setRGB(0, 0, 0);
>  // Add points
>  for($i = 0; $i < sizeof($points); $i++)
>    $point = ms_newPointObj();
>    $point->setXY($points[$i]->x, $points[$i]->y);
>    $line = ms_newLineObj();
>    $line->add($point);
>    $shape = ms_newShapeObj(MS_SHAPE_POINT);
>    $shape->add($line);
>    $shape->set("text", $points[$i]->text);
>    $layer->addFeature($shape);
>Dan
>On 4/15/05, Gavin Simpson <gavin.simpson at ucl.ac.uk> wrote:
>>Wouter Schaubroeck wrote:
>>>Hi,
>>>I was wondering if anyone would know some good examples of generating
>>>dynamic points with php mapscript? For example: just pulling the points
>>>from (in my case: a MySQL db) a database and displaying them without a
>>>shape file? And is it possible to do queries on that layer, or
>>>displaying the attribute data? I assume not, because there's no
>>>associated dbf file.
>>>Best regards,
>>>Wouter Schaubroeck
>>See the PHP/Mapscript WIKI - which has such an example:
>>http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptAddPoint
>>Querying that layer is more problematic. You need to create a shapeObj
>>and addFeature()'s to that shapeObj etc:
>>http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PerlMapScriptExamples42ex1
>>shows you how to do this with Perl which is easily translated to PHP (I
>>did it yesterday but my code is in a mess of other trial stuff just
>>now), with one major exception! PHP/Mapscript is broken at the moment
>>and you can't set the index of a shapeObj added to a layer (it needs to
>>be numeric, integer, incrementing in steps of 1 - so not a arbitrary
>>ordering of ID's from a mysql table index, currently it returns -1
>>error), which you need to have queryByPoint do anything useful etc. See:
>>http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=806
>>A patch has been accepted for this bug so you can download a nightly or
>>the cvs of mapserver (or replace php_mapscript.c in the tarball of
>>mapserver4.4.2 with the one in that bug report) and roll your own
>>php_mapscript.so.
>>After a few errors I have just gotten this compiling as well (a
>>nightly), so maybe I can query that layer after all... :-)
>>Please note - I'm a mapserver virgin so I've been bumbling through this
>>for only a day or so - feel free to email me further about this but I
>>can't guarantee I'll be able to help much beyond providing some very
>>early php code.
>>G
>>Gavin Simpson                     [T] +44 (0)20 7679 5522
>>ENSIS Research Fellow             [F] +44 (0)20 7679 7565
>>ENSIS Ltd. & ECRC                 [E] gavin.simpsonATNOSPAMucl.ac.uk
>>UCL Department of Geography       [W] http://www.ucl.ac.uk/~ucfagls/cv/
>>26 Bedford Way                    [W] http://www.ucl.ac.uk/~ucfagls/
>>London.  WC1H 0AP.
More information about the MapServer-users
