queryByPoint() php/mapscript help?
Gavin Simpson
gavin.simpson at UCL.AC.UK
Fri Apr 15 13:50:38 EDT 2005
Dear list,
I'm finally admitting defeat one this one and am asking for some help or
a pointer or two.
I compiled mapscript 4.4.2 on my Fedora Core 3 box, but replaced
php_mapscript.c with the one Camden Daily submitted to bugzilla to fix
the bug that won't allow you to set the index of a shapeObj. Note that I
have also compiled the latest nightly and I get the same behaviour as I
describe below but reverted to 4.4.2 because the nightly was doing some
strange things when drawing polygons.
I am adding points to a layer dynamically from a MySQL database and the
lat/lon stored therein. As well, I am adding point features (lines with
one point) to the same layer and am setting the index for the point so I
can query this layer later. This works fine and I have a zoomable, map
of Europe with the points of my lakes displayed.
When I come to query the layer using queryByPoint(), no matter what I
do, I always end up with the last shape point I added to the layer I'm
trying to query. So I always get 1 back from getNumResults() no matter
where I click on the map - over a point or not, and the returned shape
from getShape() is always the last shape I added.
I can't see how to make this work properly - what am I doing wrong?
If you want to see what I mean, go to
http://ecrc3.geog.ucl.ac.uk/maps/test/europe.phpms select the query
radio button and click on a point - or anything. The debug code will be
displayed next to the map illustrating the problem nicely.
I've posted my PHP code on my webserver as it looks horrible wrapped in
my mailer:
http://ecrc3.geog.ucl.ac.uk/maps/test/query_problem.txt
Here is my map file:
NAME "eurolimpacs"
SIZE 600 600
STATUS ON
SYMBOLSET "/var/www/html/maps/symbols/symbols.sym"
EXTENT -31.290 27.637 50.375 80.765
UNITS DD
SHAPEPATH "/var/www/html/maps/data"
WEB
IMAGEPATH "/var/www/html/maps/tmp/"
IMAGEURL "/maps/tmp/"
END
LAYER
NAME "Europe"
TYPE POLYGON
STATUS ON
DATA "Europe"
CLASS
STYLE
COLOR 255 255 255
OUTLINECOLOR 0 0 0
SYMBOL 0
END
END
END
LAYER
NAME "Lakes"
TYPE POINT
STATUS ON
TOLERANCE 0.1
# Need fake template for querys to work
TEMPLATE "bogus.html"
CLASS
NAME "0"
STYLE
COLOR 255 0 0
MAXSIZE 300
SYMBOL 'circle'
SIZE 5
END
END
END
END
Thanks in advance,
Gav
Gavin Simpson
ENSIS Research Fellow [F] +44 (0)20 7679 7565
ENSIS Ltd. & ECRC [E] gavin.simpsonATNOSPAMucl.ac.uk
UCL Department of Geography [W] http://www.ucl.ac.uk/~ucfagls/cv/
26 Bedford Way [W] http://www.ucl.ac.uk/~ucfagls/
London. WC1H 0AP.
