C# question
Sean Gillies
sgillies at FRII.COM
Sat Apr 16 10:48:08 EDT 2005
On Apr 16, 2005, at 7:57 AM, Constantin Cristian wrote:
> This is a multi-part message in MIME format.
> ------=_NextPart_000_0355_01C542A5.509D2480
> Content-Type: text/plain;
> charset="iso-8859-1"
> Content-Transfer-Encoding: quoted-printable
> Hello
> Does any one any idea how to implement i_obj.write method instead of =
> i_obj.save, for example if I want to use the stream with =
> "System.Drawing.Bitmap.FromStream" method.
> Here is some code:
> mapObj m_obj =3D new mapObj("C:\\ms4w\\apps\\work\\test.map");=20
> Console.WriteLine ("# Map layers " + m_obj.numlayers + "; Map name =3D
> + m_obj.name);=20
> for (int i=3D0; i<m_obj.numlayers; i++)=20
> Console.WriteLine("Layer [" + i + "] name: " + m_obj.getLayer(i).name);
> imageObj i_obj =3D m_obj.draw();
> Console.WriteLine("Image URL =3D " + i_obj.imageurl + "; Image path
> =3D =
> " + i_obj.imagepath);=20
> Console.WriteLine("Image height =3D " + i_obj.height + "; width =3D "
> i_obj.width);=20
> i_obj.save("test.png",m_obj);
> Any sample code will be greatly appreciated....:)
For versions before 4.5, the Python mapscript module has a
imageObj.write method. You could look at that for an example.
Beginning with version 4.6 we have a standard imageObj.getBytes method
that is shared by all mapscripts (except PHP). However, it requires a
small bit of extra code that is language specific and converts
getByte's output structure into a string or array type for the target
language. So far we only have these typemaps for Java and Python.
The C# module is in need of someone(s) who will study the details of
SWIG/C# and implement the proper typemap. Not being a C# user myself,
I can not justify spending my personal resources on this, but I can
provide some general assistance and coaching on how to write SWIG
typemaps.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
