C# question
    Constantin Cristian
    constantin.a.cristian at GMAIL.COM
    Sat Apr 16 06:57:03 PDT 2005
Hello
Does any one any idea how to implement i_obj.write method instead of i_obj.save, for example if I want to use the stream with "System.Drawing.Bitmap.FromStream" method.
Here is some code:
mapObj m_obj = new mapObj("C:\\ms4w\\apps\\work\\test.map");
Console.WriteLine ("# Map layers " + m_obj.numlayers + "; Map name = " + m_obj.name);
for (int i=0; i<m_obj.numlayers; i++)
Console.WriteLine("Layer [" + i + "] name: " + m_obj.getLayer(i).name);
imageObj i_obj = m_obj.draw();
Console.WriteLine("Image URL = " + i_obj.imageurl + "; Image path = " + i_obj.imagepath);
Console.WriteLine("Image height = " + i_obj.height + "; width = " + i_obj.width);
i_obj.save("test.png",m_obj);
Any sample code will be greatly appreciated....:)
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050416/dfb524bd/attachment.htm>
More information about the MapServer-users
