Search returned no results
Pericles S. Nacionales
nacional at CBS.UMN.EDU
Sun Apr 17 13:51:51 EDT 2005
For an incomplete set of examples ;), see
http://terrasip.gis.umn.edu/projects/tutorial/section3.html
-Perry
On Sunday 17 April 2005 11:29 am, Jeffrey Johnson wrote:
> Problem solved. Thanks! Im off to the template reference which doesn't
> seem to offer any examples of templates for query results. Have you
> any better links for something like this.
> Thanks a bunch,
> Jeff
> On 4/17/05, Sean Gillies <sgillies at frii.com> wrote:
> > You need to define query templates for your layers. Any value will do.
> > I like to do something like this:
> > LAYER
> > TEMPLATE "MapServers developers are a bit sadistic and insist on
> > hazing new users with this poorly documented control over
> > query-ability. How many user hours have been lost to this gotcha?
> > I'll bet it's many thousands."
> > END
> > cheers,
> > Sean
> > On Apr 17, 2005, at 9:02 AM, Jeffrey Johnson wrote:
> > > Nope. I tried values up to 100 and no luck. The polygon layer covers
> > > nearly all of the map area, so this shouldn't a problem. I am also
> > > having trouble getting the legend to work. An image seems to be
> > > generated, but its empty. Is there something wrong with my mapfile
> > > that allows the map to be generated, but other modules not to work?
> > > Thanks,
> > > Jeff=20
> > > On 4/17/05, Kralidis,Tom [Burlington] <Tom.Kralidis at ec.gc.ca> wrote:
> > >> =20
> > >> Try setting tolerance in the LAYER object (i.e. TOLERANCE 10).
> > >> =20
> > >> ..Tom
> > >> =20
> > >> =20
> > >>> -----Original Message-----
> > >>> From: UMN MapServer Users List
> > >>> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Jeffrey Johnson
> > >>> Sent: Sunday, 17 April, 2005 09:36
> > >>> To: MAPSERVER-USERS at LISTS.UMN.EDU
> > >>> Subject: [UMN_MAPSERVER-USERS] Search returned no results
> > >>> I'm having trouble getting query mode to work in my first
> > >>> mapserver application. The standard "msQueryByPoint(): Search
> > >>> returned no results. No matching record(s) found. " is
> > >>> returned. The map file and template seem pretty simple and
> > >>> straightforward. I checked that img.x and img.y are being
> > >>> passed. Not sure whats up. Any ideas?
> > >>> Jeff
> > >>> ----Map File-----
> > >>> MAP
> > >>> NAME SDNHMPaleo
> > >>> STATUS ON
> > >>> SIZE 800 600
> > >>> EXTENT 6150763 1775304 6613436 2129759
> > >>> UNITS METERS
> > >>> SHAPEPATH "/home/www/sdnhmpaleo/data"
> > >>> IMAGECOLOR 230 230 230
> > >>> SYMBOLSET 'symbols.sym'
> > >>> FONTSET "fonts/fonts.list"
> > >>> DEBUG ON
> > >>> IMAGETYPE PNG
> > >>> WEB
> > >>> HEADER 'header.html'
> > >>> FOOTER 'footer.html'
> > >>> TEMPLATE 'map.htm'
> > >>> IMAGEPATH '/home/www/sdnhmpaleo/temp/'
> > >>> IMAGEURL '/sdnhmpaleo/temp/'
> > >>> MINSCALE 50000
> > >>> MAXSCALE 5000000
> > >>> LOG '/home/www/sdnhmpaleo/sdnhmpaleo.log'
> > >>> END
> > >>> SCALEBAR
> > >>> IMAGECOLOR 255 255 255
> > >>> LABEL
> > >>> COLOR 0 0 0
> > >>> SIZE TINY
> > >>> END
> > >>> STYLE 1
> > >>> SIZE 300 10
> > >>> COLOR 0 0 0
> > >>> UNITS MILES
> > >>> INTERVALS 2
> > >>> TRANSPARENT FALSE
> > >>> STATUS EMBED
> > >>> POSITION LR
> > >>> END
> > >>> LAYER
> > >>> NAME geology
> > >>> DATA cal-geol2
> > >>> STATUS OFF
> > >>> TYPE POLYGON
> > >>> CLASSITEM 'ptype'
> > >>> LABELITEM 'ptype'
> > >>> CLASS
> > >>> EXPRESSION 'water'
> > >>> COLOR 190 232 255
> > >>> OUTLINECOLOR 0 0 0
> > >>> END
> > >>> CLASS
> > >>> EXPRESSION 'Q'
> > >>> COLOR 255 255 179
> > >>> OUTLINECOLOR 0 0 0
> > >>> END
> > >>> *** More classes here ***
> > >>> END
> > >>> LAYER
> > >>> NAME roads
> > >>> DATA SD-Freeways2
> > >>> STATUS OFF
> > >>> TYPE LINE
> > >>> CLASS
> > >>> COLOR 0 0 0
> > >>> END
> > >>> END
> > >>> LAYER
> > >>> NAME localities
> > >>> DATA localities
> > >>> STATUS OFF
> > >>> TYPE POINT
> > >>> CLASS
> > >>> SYMBOL 'circle'
> > >>> COLOR 255 0 0
> > >>> MINSIZE 5
> > >>> END
> > >>> END
> > >>> END
> > >>> ----End Map File-----
> > Sean Gillies
> > sgillies at frii dot com
> > http://users.frii.com/sgillies
Dept. of Ecology, Evolution, and Behavior
University of Minnesota
work: 612 624 6713
e-mail: nacional at cbs.umn.edu
