MyGIS, Mapfile, and MapScript
    Don Deskins
    dldeskins at GMAIL.COM
    Mon Apr 18 09:50:37 PDT 2005
It must be monday!
the errors are as follows:
Warning: [MapServer Error]: msDrawMap(): Failed to draw layer named
'Parcels'. in <path> on line 274
Warning: [MapServer Error]: msMYGISLayerGetShapeRandom(): GetShape called on
MYGIS layer with invalid DB query results. in <path> on line 274
Warning: [MapServer Error]: SELECT feature.id, feature.vertices,
geometry.WKB_GEOMETRY from mysql query failed : mysql query failed in <path>
on line 274
Fatal error: Call to a member function on a non-object in <path> on line 276
Can anyone suggest what the problem may be?
Thanks,
More information about the MapServer-users
