MyGIS, Mapfile, and MapScript
    Lowell Filak
    lfilak at MEDINACO.ORG
    Wed Apr 20 06:20:12 PDT 2005
The following message was sent by Don Deskins <dldeskins at GMAIL.COM> on
Mon, 18 Apr 2005 11:50:37 -0500.
> It must be monday!
> the errors are as follows:
> Warning: [MapServer Error]: msDrawMap(): Failed to draw layer named
> 'Parcels'. in <path> on line 274
> Warning: [MapServer Error]: msMYGISLayerGetShapeRandom(): GetShape
called on
> MYGIS layer with invalid DB query results. in <path> on line 274
> Warning: [MapServer Error]: SELECT feature.id, feature.vertices,
> geometry.WKB_GEOMETRY from mysql query failed : mysql query failed in
<path>
> on line 274
> Fatal error: Call to a member function on a non-object in <path> on
line 276
> Can anyone suggest what the problem may be?
Don,
I'm confused, from your previous posts I can't determine if you imported
your data into mysql using the shp2mysql.pl routine. If not, that is
most likely the problem. The third error line above seems to indicate
that the geometry fields expected by the mygis reader do not exist.
If you do a 'select * from <table_name>\g' at the mysql prompt does the
data appear to be there?
Lowell
Lowell
More information about the MapServer-users
