SWF OUTPUT_MOVIE=SINGLE resolution?
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Wed Apr 20 13:57:44 EDT 2005
Chris,
Is this a problem with layers containing labels ? Can you disable
layers with labels and try it again with OUTPUT_MOVIE=SINGLE ?
Basically if you want to use OUTPUT_MOVIE=SINGLE, you need to use true
type fonts instead of FDB fonts as explained in the post.
Later,
Chris Hackel wrote:
> Outputting SWF, when I set OUTPUT_MOVIE=SINGLE I get
> an empty movie. When it's MULTIPLE it works fine. This
> problem was described here:
> http://lists.gis.umn.edu/pipermail/mapserver-dev/2004-June/001112.html
> but I could not find any sort of resolution. I'm using
> mapserver 4.4.2.
> Any assistance would be much appreciated!
> Thank you,
> Chris
> Full file:
> MAP
> EXTENT -74.047185 40.679548 -73.907005 40.882078
> SIZE 400 300
> PROJECTION
> "init=epsg:4269"
> END
> WEB
> TEMPLATE "tigermap.html"
> IMAGEPATH
> "/Library/WebServer/Documents/tigertest/tmp/"
> IMAGEURL "/tigertest/tmp/"
> END
> OUTPUTFORMAT
> NAME swf
> DRIVER "SWF"
> MIMETYPE "application/x-shockwave-flash"
> EXTENSION "swf"
> IMAGEMODE PC256
> FORMATOPTION "OUTPUT_MOVIE=SINGLE"
> END
> IMAGETYPE swf
> LAYER
> NAME Complete_Chain
> TYPE LINE
> STATUS DEFAULT
> CONNECTIONTYPE OGR
> CONNECTION
> "/Library/WebServer/Documents/tigertest/tgr36061"
> CLASS
> COLOR 153 102 0
> END
> END # Layer
> END
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
