SWF OUTPUT_MOVIE=SINGLE resolution?
Chris Hackel
cvhackel at YAHOO.COM
Wed Apr 20 13:12:18 EDT 2005
Outputting SWF, when I set OUTPUT_MOVIE=SINGLE I get
an empty movie. When it's MULTIPLE it works fine. This
problem was described here:
http://lists.gis.umn.edu/pipermail/mapserver-dev/2004-June/001112.html
but I could not find any sort of resolution. I'm using
mapserver 4.4.2.
Any assistance would be much appreciated!
Thank you,
Chris
Full file:
MAP
EXTENT -74.047185 40.679548 -73.907005 40.882078
SIZE 400 300
PROJECTION
"init=epsg:4269"
END
WEB
TEMPLATE "tigermap.html"
IMAGEPATH
"/Library/WebServer/Documents/tigertest/tmp/"
IMAGEURL "/tigertest/tmp/"
END
OUTPUTFORMAT
NAME swf
DRIVER "SWF"
MIMETYPE "application/x-shockwave-flash"
EXTENSION "swf"
IMAGEMODE PC256
FORMATOPTION "OUTPUT_MOVIE=SINGLE"
END
IMAGETYPE swf
LAYER
NAME Complete_Chain
TYPE LINE
STATUS DEFAULT
CONNECTIONTYPE OGR
CONNECTION
"/Library/WebServer/Documents/tigertest/tgr36061"
CLASS
COLOR 153 102 0
END
END # Layer
END
