consolidation of .map file contents
Dylan Beaudette
dylan at IICI.NO-IP.ORG
Wed Apr 20 17:10:51 EDT 2005
Steve,
Thanks for the input. To clarify a bit, we have county -by-county information,
with associated data in a MySQL database that is accessed via Mapserver-style
query templates and PHP.
There are 2 current reasons why each county has its own .map file (and they
might not even be very good ones, i hope!):
1. each map obviously has a different:
-context map image
-geographic extent
-shape file for the main content, rendered according to the county
2. the query results need to contain a unique county ID
a lot of these problems could be resolved if i could figure out how to pass
mapserver configuration parameters in the URL: i.e. the county ID, the
geographic extent, and the name of the shape file containing the main content
for that county.
does this seem reasonable?
thanks!
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
On Wednesday 20 April 2005 11:47 am, Stephen Woodbridge wrote:
> All of your ideas are valid and can work depending on what you are try
> to accomplish. I know Ed at Topozone.com is using template mapfile
> fragments and using the cpp and Makefiles to generate a large number of
> mapfiles based on change the DEFINES. That way if you need to make a
> change to a section that is in all your mapfiles you just change one
> file and type make.
> But before you solve the technology, you might want to describe why you
> need 200 mapfiles and what type of things are changing from one to the
> other. There might be much better solutions.
> -Steve W.
> Dylan Beaudette wrote:
> > Hi everyone,
> > We have been using Mapserver for about a year now with a great deal of
> > success on small projects (i.e. single map file, single html template,
> > single query template).
> > Now that we are considering a more complicated project with nearly 200
> > .map files and their associated html templates and query templates -
> > quite a bit to manage should any cosmetic changes need to be made in
> > the map files.
> > Is there any way to "include" bits of a central map file to consolidate
> > the configuration of such a large project, or would it be better to use
> > a single .map file, customizing it through the URL passed to it...
> > ...or is phpmapscript a viable option?
> > thanks in advancce for any ideas!
> > Dylan Beaudette
> > 530.754.7341
