Antwort: [UMN_MAPSERVER-USERS] Mapserver crash with gd and
antialiasing?
Justin Schoeman
justin at EXPERTRON.CO.ZA
Thu Apr 21 10:16:06 EDT 2005
Thanks for the help - I see it is a problem in libgd - the clipping must
be broken as it is trying to renderr off the bottom of the image...
Thanks again,
Justin
Jürgen Link wrote:
> Justin,
> you may want to invoke mapserver on the command line:
> mapserv "QUERY_STRING=<parameter_list>"
> Replace <parameter_list> by your actual query string from your actual URL
> (i.e. the stuff behind the question mark).
> Output goes to stdout and you'll maybe see some hints.
> You may also want to set the "DEBUG ON" option in your map file to make
> output verbose.
> Jürgen
> Dr. Jürgen Link
> BGS Systemplanung AG
> http://www.bgs-ag.de
> E-Mail juergen.link at bgs-ag.de
> Phone: 02241 166-530
> Fax: 02241 166-680
> Mobile: 0160 97262616
> | | Justin Schoeman |
> | | <justin at EXPERTRON.CO|
> | | .ZA> |
> | | Gesendet von: UMN |
> | | MapServer Users List|
> | | <MAPSERVER-USERS at LIS|
> | | TS.UMN.EDU> |
> | | 21.04.2005 15:24 |
> | | Bitte antworten an |
> | | Justin Schoeman |
> | An: MAPSERVER-USERS at LISTS.UMN.EDU |
> | Kopie: |
> | Thema: [UMN_MAPSERVER-USERS] Mapserver crash with gd and antialiasing? |
> Hi everybody,
> I am trying to use mapserver to render maps. The basic rendering works
> great, but antialiasing is giving me a lot of trouble.
> After finally figuring out to use TrueColour visuals (RGB instead of PC256)
> for PNG output in libgd (libgd 2.0.33), antialiasing started working
> _but_...
> Some lines cause mapserv (cgi interface) to die (probably a segfault, only
> 'Premature end of script headers: /var/www/cgi-bin/mapserv' gets logged).
> I
> have experienced this with CARTOLINE and ELIPSE styles. Without
> antialiasing everything works fine. With antialiasing it sometimes just
> dies...
> I am not sure exactly what lines trigger the problem though. I know that
> enabling antialiasing on some layers will cause mapserver to die at some
> scale factors... If anybody has any ideas on how to track further, please
> let me know ;-).
> This problem has been verified on mapserver version 4.4.1 and 4.4.2.
> Any help would be greatly appreciated.
> Thanks,
> Justin
