Mapserver for Windows 2003 + FCGI + SDE
Mark Leslie
mark at REFRACTIONS.NET
Thu Apr 21 13:30:43 EDT 2005
Frank,
I've managed to clear some of the errors I'm having, thanks to your
advice, but I'm still getting a fault in the libfcgi.dll. I am using
mapserv.c v1.141.2.2, which sports calls to msResetErrorList, but I'm
still getting the a persistant error stack, which I would guess could be
the cause of my fault. Do you have any ideas as to why this is still
happening?
Mark
Frank Warmerdam wrote:
>On Apr 12, 2005 12:15 PM, Mark Leslie <mark at refractions.net> wrote:
>>I'm having trouble building mapserver on a Windows 2003 server with
>>ArcSDE and fastcgi support. I can compile it, and it runs for a while,
>>but I eventually get memory faults in msvcrt.dll and libfcgi.dll. I have
>>tryed this with Mapservers 4.4, 4.4.1 and now 4.4.2. I've compiled using
>>both vc6 and vc7. Two things that may be relevent: I'm using the
>>precompiled gd binaries; the error stack does not seem to be clearing
>>between requests. I was under the impression that the error stack issue
>>had been taken care of around the 4.4 release.
>Mark,
>The error stack reset for FastCGI support is in MapServer 4.4.1. It
>is version 1.141.2.1 of mapserv.c (calls msResetErrorList() after
>completing - or failing - an OWS request).
>>This build has worked
>>fine before on Win2000. If anyone has had similar problems, or has any
>>ideas, I would appreciate it.
>I don't know why you are running into problems on Win2003 that
>didn't occur on Win2000. I will say that the build process is complex
>including the need to past the fastcgi client library (as noted in the
>wiki) and care must be taken to build with MSVCRT.DLL. I haven't
>tried with VC7, but I think that would be imprudent.
>I think the precompiled binaries for GD are fine as long as you
>build with VC6 and /MD.
>Best regards,
>I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush | Geospatial Programmer for Rent
