Mapserver for Windows 2003 + FCGI + SDE
Mark Leslie
mark at REFRACTIONS.NET
Tue Apr 12 13:43:59 EDT 2005
For vc7 I'm using the platform sdk and vc7 toolkit. For vc6 it's the
visual studio tools. I tryed the 2003 tools after vc6 started causing
the errors, in case the old tools didn't like the new libraries
(%SystemRoot%\system32\msvcrt.dll is version 7.0.3790.0 on my win2003,
6.1.9844.0 on win2000). I'll try again with vc6 and the mapserv.c
changes Frank directed me too and see how things go.
Mark
Bart van den Eijnden wrote:
> Mark,
> did you download any of the Windows Platform SDK's?
> You could try building against the Windows 2003 Server Platform SDK,
> but I don't know if that will help for sure. Update your LIB and
> INCLUDE environment variables to include the Platform SDK files first.
> http://www.microsoft.com/msdownload/platformsdk/sdkupdate/
> Btw this site needs IE :-( :
> Best regards,
> Bart
> On Tue, 12 Apr 2005 09:15:54 -0700, Mark Leslie
> <mark at REFRACTIONS.NET> wrote:
>> I'm having trouble building mapserver on a Windows 2003 server with
>> ArcSDE and fastcgi support. I can compile it, and it runs for a while,
>> but I eventually get memory faults in msvcrt.dll and libfcgi.dll. I have
>> tryed this with Mapservers 4.4, 4.4.1 and now 4.4.2. I've compiled using
>> both vc6 and vc7. Two things that may be relevent: I'm using the
>> precompiled gd binaries; the error stack does not seem to be clearing
>> between requests. I was under the impression that the error stack issue
>> had been taken care of around the 4.4 release. This build has worked
>> fine before on Win2000. If anyone has had similar problems, or has any
>> ideas, I would appreciate it.
>> Mark
