Chameleon question
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Fri Apr 22 03:50:04 EDT 2005
Check if your Chameleon config references the 24 bits PNG output format of your MAP file (NAME attribute of OUTPUTFORMAT as param-value).
<context-param>
<param-name>image_type</param-name>
<param-value>PNG</param-value>
<description>Output image type (eg: PNG, GIF). Must be uppercase. This image format MUST be supported by your browser and GD (on the server). Please don't change that value unless you know what you'r doing.</description>
</context-param>
Best regards,
Bart
Syncera-ITSolutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Ferencik Ioan <ferencik.ioan at PERSONAL.RO> 04/22/05 09:45am >>>
Hi list,
I use the same map file with phpmapscript and chameleon but the raster data i
use does not have the same quality. (with phpmapscript i see a a nice continous
DEM but with chameleon there are less colors, something like classes.) Do you
know why?
_____________________________________________
Cinefil?Castiga o excursie la Venetia
http://www.cineplus.ro/concurs
