changing DATA parameter in mapfile via URL [fixed]
Dylan Beaudette
dylan at IICI.NO-IP.ORG
Fri Apr 22 10:40:26 EDT 2005
Thank you everyone who has offered suggestions, i now have my
application working with parameter substitution .
cheers!
On Apr 22, 2005, at 3:56 AM, Smith, Michael ERDC-CRREL-NH wrote:
> You need to use the DATAPATTERN keyword to allow data changes at the
> URL level. See the docs at
> http://mapserver.gis.umn.edu/doc44/mapfile-reference.html#map.
> DATAPATTERN is a regular expression that gets applied to any requests
> to change data. Its a security thing.
> Mike
> From: UMN MapServer Users List on behalf of Dylan Beaudette
> Sent: Thu 4/21/2005 5:48 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] changing DATA parameter in mapfile via
> URL
> Is is possible to change the 'DATA' parameter via a URL-style variable
> such
> as:
> ...&map_layername_data="xxx.shp"
> i am able to change every other property of this layer, but not its
> data
> source.
> if this is not possible, does anyone know of some kind of work-around?
> i am trying to use a single map file for numerous different shape
> files...
> thanks in advance!
> Dylan Beaudette
> Soils and Biogeochemistry Graduate Group
> University of California at Davis
> 530.754.7341
Dylan Beaudette
530.754.7341
