strange shapefile DBF error
    Stephen Woodbridge
    woodbri at SWOODBRIDGE.COM
    Fri Apr 22 17:49:39 PDT 2005
Dylan Beaudette wrote:
> Greetings,
> recently installed gdal-1.2.6 and mapserver-4.4.2 on a slackware 10 box.
> trying to access a simple shapefile with ogrinfo yields an 'illegal
> instruction' after only 1 record in the shapefile has been processed.
> i know that this shapefile is in working order.
> trying to re-create this shapefile (it is a tile index for mapserver) seems to
> fail as well...
> tile4ms list test
> Aborted. Unable to open DBF:o34115d1ne.tif
> Processed 0 of 1 files
OK, tile4ms only works for shapefiles and the file you are trying to
open is a tif. You need to be using gdaltindex.
-Steve W.
> here is the output from ogrinfo;
> ogrinfo -al doqq_index.shp
> INFO: Open of `doqq_index.shp'
> using driver `ESRI Shapefile' successful.
> Layer name: doqq_index
> Geometry: Polygon
> Feature Count: 312
> Extent: (-2527391.972465, -374934.820857) - (-2007497.075791, 174428.925500)
> Layer SRS WKT:
> PROJCS["North_America_Albers_Equal_Area_Conic",
>     GEOGCS["GCS_North_American_1983",
>         DATUM["North_American_Datum_1983",
>             SPHEROID["GRS_1980",6378137.0,298.257222101]],
>         PRIMEM["Greenwich",0.0],
>         UNIT["Degree",0.0174532925199433]],
>     PROJECTION["Albers_Conic_Equal_Area"],
>     PARAMETER["False_Easting",0.0],
>     PARAMETER["False_Northing",0.0],
>     PARAMETER["longitude_of_center",-96.0],
>     PARAMETER["Standard_Parallel_1",20.0],
>     PARAMETER["Standard_Parallel_2",60.0],
>     PARAMETER["latitude_of_center",40.0],
>     UNIT["Meter",1.0]]
> location: String (255.0)
> OGRFeature(doqq_index):0
>   location (String) = o34115d1ne.tif
> Illegal instruction
> and here are my compile-time options for gdal:
> export CHOST="i686-pc-linux-gnu"
> export CFLAGS="-march=pentium3 -O3 -pipe -fomit-frame-pointer"
> export CXXFLAGS="-march=pentium3 -O3 -pipe -fomit-frame-pointer"
> ./configure --prefix=/usr --with-png=internal --with-jpeg=internal \
>             --with-gif=internal --with-libtiff=internal \
>             --with-geotiff=internal --with-libz=internal\
>             --without-pg --without-ogdi --with-python \
>             --with-threads=yes
> any ideas.. ? could this be an issue that is due to some other library not
> being present?
> thanks in advance!
> Dylan Beaudette
> Soils and Biogeochemistry Graduate Group
> University of California at Davis
> 530.754.7341
More information about the MapServer-users
