strange shapefile DBF error
Dylan Beaudette
dylan at IICI.NO-IP.ORG
Fri Apr 22 20:08:59 EDT 2005
Greetings,
recently installed gdal-1.2.6 and mapserver-4.4.2 on a slackware 10 box.
trying to access a simple shapefile with ogrinfo yields an 'illegal
instruction' after only 1 record in the shapefile has been processed.
i know that this shapefile is in working order.
trying to re-create this shapefile (it is a tile index for mapserver) seems to
fail as well...
tile4ms list test
Aborted. Unable to open DBF:o34115d1ne.tif
Processed 0 of 1 files
here is the output from ogrinfo;
ogrinfo -al doqq_index.shp
INFO: Open of `doqq_index.shp'
using driver `ESRI Shapefile' successful.
Layer name: doqq_index
Geometry: Polygon
Feature Count: 312
Extent: (-2527391.972465, -374934.820857) - (-2007497.075791, 174428.925500)
Layer SRS WKT:
PROJCS["North_America_Albers_Equal_Area_Conic",
GEOGCS["GCS_North_American_1983",
DATUM["North_American_Datum_1983",
SPHEROID["GRS_1980",6378137.0,298.257222101]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Albers_Conic_Equal_Area"],
PARAMETER["False_Easting",0.0],
PARAMETER["False_Northing",0.0],
PARAMETER["longitude_of_center",-96.0],
PARAMETER["Standard_Parallel_1",20.0],
PARAMETER["Standard_Parallel_2",60.0],
PARAMETER["latitude_of_center",40.0],
UNIT["Meter",1.0]]
OGRFeature(doqq_index):0
location (String) = o34115d1ne.tif
Illegal instruction
and here are my compile-time options for gdal:
export CHOST="i686-pc-linux-gnu"
export CFLAGS="-march=pentium3 -O3 -pipe -fomit-frame-pointer"
export CXXFLAGS="-march=pentium3 -O3 -pipe -fomit-frame-pointer"
./configure --prefix=/usr --with-png=internal --with-jpeg=internal \
--with-gif=internal --with-libtiff=internal \
--with-geotiff=internal --with-libz=internal\
--without-pg --without-ogdi --with-python \
--with-threads=yes
any ideas.. ? could this be an issue that is due to some other library not
being present?
thanks in advance!
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
