global mapping issues with orthographic projection
Sean Gillies
sgillies at FRII.COM
Wed Apr 27 16:44:34 EDT 2005
On Apr 27, 2005, at 2:30 PM, Ken Tanaka wrote:
> As an update/resolution to this problem, we now have a corrected map
> file that generates the image we want.
> The resulting imag is online:
> http://gdsg.ngdc.noaa.gov/starburst/OrthoOutlines.html
> The image was positioned to correspond to the GOES-EAST geostationary
> satellite data we will be processing.
> Thanks again for the help from this email list.
> MAP
> IMAGETYPE GIF
> EXTENT -6400000 -6400000 6400000 6400000
> SHAPEPATH "/df_env/MMS/"
> PROJECTION
> "+proj=ortho"
> "+lat_0=0.0"
> "+lon_0=-75.0"
> END
> # Start of LAYER DEFINITIONS
> LAYER # States polygon layer begins here
> NAME states
> DATA "statesp020"
> STATUS off
> TYPE polygon
> CLASS
> COLOR 0 0 0
> OUTLINECOLOR 255 0 0
> END
> PROJECTION
> "init=epsg:4326"
> END
> END # States polygon layer ends here
> LAYER # Countries polygon layer begins here
> NAME countries
> DATA "countries"
> STATUS off
> TYPE polygon
> CLASS
> COLOR 0 0 0
> END
> PROJECTION
> "init=epsg:4326"
> END
> END # Countries polygon layer ends here
> # End of LAYER DEFINITIONS
> END
> Ken Tanaka wrote:
>> At the moment we are having some troubles with a "starburst" of stray
>> feature lines that can be seen in this URL:
>>>> Our current approach is to generate the lines with MMS, and then
>>>> use a
>>>> separate step to merge the data (satellite image) with the outlines
>>>> image,
>>>> and produce the composite image seen in the above URL.
>>> Frank Warmerdam wrote:
>>> Is there a reason you don't have MapServer taking care of the image
>>> data
>>> as well?
>> I think having MapServer handle the image data would be a good
>> approach
>> as well. We are currently trying MapServer out by replacing older
>> software in an existing system. I'll need to find out why the merging
>> is
>> done separately, there may be a performance issue there.
> Primarily we are taking this approach as an efficiency step. The data
> images will remain in the same perspective, so we can use MapServer for
> the overlay one time for this perspective. This is potentially a large
> number of images, especially if we are required to re-process the
> existing archive.
> -Ken
Ken,
Instead of declaring a black fill for your country and states polygon
and then making black transparent, you can simply omit the fill color.
The result is will be a stroked polygon with no fill at all, and will
overlay your image nicely. Should be faster, too.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
