global mapping issues with orthographic projection
Ken Tanaka
Ken.Tanaka at NOAA.GOV
Wed Apr 27 16:30:26 EDT 2005
As an update/resolution to this problem, we now have a corrected map
file that generates the image we want.
The resulting imag is online:
http://gdsg.ngdc.noaa.gov/starburst/OrthoOutlines.html
The image was positioned to correspond to the GOES-EAST geostationary
satellite data we will be processing.
Thanks again for the help from this email list.
MAP
IMAGETYPE GIF
EXTENT -6400000 -6400000 6400000 6400000
SHAPEPATH "/df_env/MMS/"
PROJECTION
"+proj=ortho"
"+lat_0=0.0"
"+lon_0=-75.0"
END
# Start of LAYER DEFINITIONS ---------------------------------------------
LAYER # States polygon layer begins here
NAME states
DATA "statesp020"
STATUS off
TYPE polygon
CLASS
COLOR 0 0 0
OUTLINECOLOR 255 0 0
END
PROJECTION
"init=epsg:4326"
END
END # States polygon layer ends here
LAYER # Countries polygon layer begins here
NAME countries
DATA "countries"
STATUS off
TYPE polygon
CLASS
COLOR 0 0 0
END
PROJECTION
"init=epsg:4326"
END
END # Countries polygon layer ends here
# End of LAYER DEFINITIONS ---------------------------------------------
END
Ken Tanaka wrote:
> At the moment we are having some troubles with a "starburst" of stray
> feature lines that can be seen in this URL:
>>> Our current approach is to generate the lines with MMS, and then use a
>>> separate step to merge the data (satellite image) with the outlines
>>> image,
>>> and produce the composite image seen in the above URL.
>> Frank Warmerdam wrote:
>> Is there a reason you don't have MapServer taking care of the image data
>> as well?
> I think having MapServer handle the image data would be a good approach
> as well. We are currently trying MapServer out by replacing older
> software in an existing system. I'll need to find out why the merging is
> done separately, there may be a performance issue there.
Primarily we are taking this approach as an efficiency step. The data
images will remain in the same perspective, so we can use MapServer for
the overlay one time for this perspective. This is potentially a large
number of images, especially if we are required to re-process the
existing archive.
-Ken
= Enterprise Data Services Division ===============
| CIRES, National Geophysical Data Center / NOAA |
= Ken.Tanaka(a)noaa.gov ===========================
