Virtual Data Source and wkbLineString
Speiser Ferenc
speiser.ferenc at FREEMAIL.HU
Tue Apr 26 06:57:00 EDT 2005
Dear List,
I try to get to work an ogrvrtDataSource layer in my Mapserver to show
as a line-layer. Althogh the ogrinfo says of the ovf file it is a line
geometry type file, but the rendered mapimage doesn't show anything of
the line.
ogrinfo -so -all measurement2.ovf
ERROR 4: Update access not supported for VRT datasources.
Had to open data source read-only.
INFO: Open of `measurement2.ovf'
using driver `VRT' successful.
Layer name: mylayer
Geometry: Line String
Feature Count: 20
ERROR 1: SetAttributeFilter() not supported on ExecuteSQL() results.
Extent: (562781.155556, 83754.050000) - (847169.890000, 305903.830000)
Layer SRS WKT:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9108"]],
AXIS["Lat",NORTH],
AXIS["Long",EAST],
AUTHORITY["EPSG","4326"]]
x: Real (0.0)
y: Real (0.0)
value: Real (0.0)
desc: String (50.0)
co2: Real (0.0)
nox: Real (0.0)
datum: String (19.0)
Could you give me some example of having a line layer in my mapimage
with the use of an ovf file?
Thanks in advance!
Feri
Speiser Ferenc Péter
University of Veszprém
Department of Automation
Phone: (00 36) 88 624 888
> -----Original Message-----
> From: L-Soft list server at University of Minnesota (1.8e)
> [mailto:LISTSERV at lists.umn.edu]
> Sent: Tuesday, April 26, 2005 11:25 AM
> To: Ferenc Speiser
> Subject: Command confirmation request (377B4C88)
> Your command:
> PW REP XXXXXXXX
> requires confirmation. To confirm the execution of your command,
simply
> point your browser to the following URL:
> http://lists.umn.edu/cgi-bin/wa?OK=377B4C88
> Alternatively, if you have no WWW access, you can reply to the
present
> message and type "ok" (without the quotes) as the text of your
message.
> Just the word "ok" - do not retype the command. This procedure will
work
> with any mail program that fully conforms to the Internet standards
for
> electronic mail. If you receive an error message, try sending a
new
> message to LISTSERV at LISTS.UMN.EDU (without using the "reply"
function -
> this is very important) and type "ok 377B4C88" as the text of
your
> message.
> Finally, your command will be cancelled automatically if LISTSERV
does
> not receive your confirmation within 48h. After that time, you must
start
> over and resend the command to get a new confirmation code. If you
change
> your mind and decide that you do NOT want to confirm the command,
simply
> discard the present message and let the request expire on its own.
> ------------------------- Original mail header
> [Request submitted through anonymous TCP/IP interface from 127.0.0.1]
