Virtual Data Source and wkbLineString
Ferenc Speiser
speiser.ferenc at FREEMAIL.HU
Tue Apr 26 08:11:20 EDT 2005
Dear List,
I try to get an ogrvrtDataSource layer work in my Mapserver to show as a
line-layer. Althogh the ogrinfo says about the ovf file, it is a line
geometry type file, but the rendered mapimage doesn't show the line.
ogrinfo -so -all measurement2.ovf
ERROR 4: Update access not supported for VRT datasources.
Had to open data source read-only.
INFO: Open of `measurement2.ovf'
using driver `VRT' successful.
Layer name: mylayer
Geometry: Line String
Feature Count: 20
ERROR 1: SetAttributeFilter() not supported on ExecuteSQL() results.
Extent: (562781.155556, 83754.050000) - (847169.890000, 305903.830000)
Layer SRS WKT: GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9108"]],
AXIS["Lat",NORTH],
AXIS["Long",EAST],
AUTHORITY["EPSG","4326"]]
x: Real (0.0)
y: Real (0.0)
value: Real (0.0)
desc: String (50.0)
co2: Real (0.0)
nox: Real (0.0)
datum: String (19.0)
Could you give me some example of having a line layer in my mapimage with
using an ovf file?
Thanks in advance!
Feri
Speiser Ferenc Péter
University of Veszprém
Department of Automation
Phone: (00 36) 88 624 888
