Does maplab 2.2 support SDE as included in the maplab_ms4w-2.2 install? If so, what does the layer reference look like? What all is required in adding an SDE layer to a map file? I have tried adding an SDE layer several times. I get an error message in Map Browser that SDE is not supported? Mike Micallef
