Finding Latitude and Longitude of the 4 corners of a map
using mapscript.
James Sohr
jms4 at PO.CWRU.EDU
Tue Apr 26 16:57:29 EDT 2005
Yes, you can calculate the lat long of your current extent by using the
RectObj's project method. For instance:
$latlong_rect = $map->extent;
$latlong_rect->project( ms_newprojectionobj($map->getProjection),
ms_newprojectionobj("proj=latlong"));
Assuming $map is your map object, the latitudes and longitudes of the four
corners of your map are now stored in $latlong_rect->minx, $latlong_rect-
>miny, $latlong_rec->maxx, and $latlong_rect->maxy .
