SQL WHERE in OGR VRT
Frank Warmerdam
fwarmerdam at GMAIL.COM
Wed Apr 27 17:33:21 EDT 2005
On 4/27/05, Fawcett, David <David.Fawcett at state.mn.us> wrote:
> As an update, this is the OVF file that I was using:
> <OGRVRTDataSource>
> <OGRVRTLayer name="facilities">
> <SrcDataSource>ODBC:myname/mypass at mydsn</SrcDataSource>
> <SrcSQL>SELECT FClass, UTMX, UTMY, NameShort FROM tlkpDestFac WHERE
> FClass = 1</SrcSQL>
> <LayerSRS>epsg:32615</LayerSRS>
> <GeometryType>wkbPoint</GeometryType>
> <GeometryField encoding="pointFromColumns" x="UTMX" y="UTMY"/>
> </OGRVRTLayer>
> </OGRVRTDataSource>
> After removing the line
David,
If this fails, it generally means that the GDAL/OGR code was unable
to find the supporting EPSG data files such as pcs.csv and gcs.csv.
These are distributed in gdal/data (in source dists.) and you can
point to them with the GDAL_DATA environment variable.
> It works. Fortunately, for this application, I don't need to project the
> data.
Right. Also, in a mapserver context the OGR coordinate system is
ignored, and you need to specify things in the .map file in a projection
block. So OGR's concept of the coordinate system is normally only
important if you are using external ogr utilities or other OGR applications.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
