map style question
Fawcett, David
David.Fawcett at STATE.MN.US
Thu Apr 28 09:20:04 EDT 2005
Sorry Chris,
I don't have the data, so I don't have an answer for you. Can't you just look at the data and see which fields they are using (assuming that they haven't pre-processed the data).
You may need to add fields to your data to classify the street types and provide 'pretty' names for labels.
My primary reason for replying was to point out the very cool javascript zoom/scale widget that they are using! Check it out!
David.
David Fawcett
Minnesota Office of Environmental Assistance
david.fawcett at moea.state.mn.us
651.215.0200
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Chris Hackel
Sent: Wednesday, April 27, 2005 10:42 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] map style question
Sorry for the newcomer question, but I'd really
appreciate it if someone could help me out. I need to
know what fields to use in order to color streets as
done in the below NYC map. How are the main streets &
avenues being identified as distinct from regular
streets? Also, what field is being used for the label
(that gives full streetname)
Thanks so much!
Chris
http://factfinder.census.gov/servlet/ReferenceMapFramesetServlet?_bm=y&-_pan=&-PANEL_ID=rm_result&-_MapEvent=&-_changeMap=ZoomIn&-_pageY=380&-_zoomLevel=&-_pageX=498&-_mapY=178&-rm_config=|b=50|l=en|t=420|zf=0.0|ms=ref_stat_00dec|dw=0.07725540836923254|dh=0.043898044520797166|dt=gov.census.aff.domain.map.EnglishMapExtent|if=gif|cx=-73.99420481140605|cy=40.72685503691364|zl=4|pz=4|bo=318:317:316:314:313:323:319|bl=362:393:358:357:356:355:354|ft=350:349:335:389:388:332:331|fl=381:403:204:380:369:379:368|g=01000US&-_mapX=337&-redoLog=false&-errMsg=&-_latitude=&-_lang=en&-_longitude=
