Trouble getting SLD working
Rod Suddaby
rsuddaby at NRCAN.GC.CA
Thu Apr 28 15:00:44 EDT 2005
Hi List:
I'm a newbie to SLD and I've been trying to figure out why my build of
mapserver will not apply the styles. I've created the following SLD xml
file:
[test_sld.xml]
<StyledLayerDescriptor version="1.0.0" xmlns="http://www.opengis.net/sld"
xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/
ogc" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.
org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/sld
http://schemas.opengeospatial.net/sld/1.0.0/StyledLayerDescriptor.xsd">
<NamedLayer>
<Name>provinces</Name>
<UserStyle>
<Name>myStyle</Name>
<FeatureTypeStyle>
<Rule>
<PolygonSymbolizer>
<Fill>
<CssParameter name="fill">#00ff00</CssParameter>
</Fill>
<Stroke>
<CssParameter name="stroke">#0000ff</CssParameter>
<CssParameter name="stroke-width">3</CssParameter>
</Stroke>
</PolygonSymbolizer>
</Rule>
</FeatureTypeStyle>
</UserStyle>
</NamedLayer>
</StyledLayerDescriptor>
The layer block of my mapfile is:
LAYER
NAME provinces
DATA prov_prj
PROJECTION
"init=epsg:42304"
END
UNITS METERS
TYPE POLYGON
STATUS ON
# CLASS
# COLOR 255 0 0
# OUTLINECOLOR 0 0 255
# END
END
I've sent the following request to the mapserver:
http://localhost/cgi-bin/mapserv?map=prov.map&version=1.1.
1&request=getMap&layers=provinces&styles=&sld=http://localhost/test_sld.xml
... and all I get is a blank image. Checking the apache access_log shows no
hit for the 'test_sld.xml' file. It seems that mapserver is simply ignoring
the sld parameter.
I've also tried putting the "wms_sld_url" tag in the layer metadata, tried
the "wms_sld_body" tag, and tried feeding the xml directly using the
sld_body parameter -- same result
Heres the output of mapserv -v:
%dragon>./mapserv -v
MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBNP
SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=TIFF INPUT=EPPL7 INPUT=POSTGIS
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
O.S. Is Suse Linux 9.1
Can anyone see if I'm missing something here?
Also, are there any other resources available regarding SLD other than the
spec and the HOWTO docs?
Thanks,
Rod.
