Labeling - Can you truncate a numeric type to not show decimals
Steve Lime
steve.lime at DNR.STATE.MN.US
Thu Apr 28 16:06:54 PDT 2005
Sorry Steve, you can't explicitly control that, you must preprocess the
attributes.
Steve
>>> Steve Lehr <lehrs at ERAU.EDU> 04/28/05 1:30 PM >>>
Hey guys - I have a topographical map and the elevation number in the
.dbf
file is defined to be a numeric field with 5 decimals: ELEVATION
N 18 5
Is there a way to simply truncate the decimals below for the field
ELEVATION that I wish to label.
LABELITEM (int) ELEVATION
I'm using CGI Mapserver and map files. Or do I have to create a new
.dbf
and add a field to the .dbf of type N with no decimals and populate it
with
a script - i.e. scrub the file.
LAYER
NAME topo
DATA topo
LABELITEM ELEVATION
CLASS
COLOR 0 0 0
LABEL
SIZE SMALL
END
END
END
Thanks -- See you in June!
More information about the MapServer-users
