Trouble getting SLD working
Suddaby, Rod
RSuddaby at NRCAN.GC.CA
Thu Apr 28 18:04:30 EDT 2005
Hi Bart,
Yes, Mapserver operates fine with the exception of the SLD.
The GetCapabilities responds with (with respect to SLD):
<UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1"
RemoteWFS="0"/>
and the 'request=getStyles' request reports back fine as well (indicating
the styles I set in the CLASS block).
Using the CLASS block without the SLD works as expected, too. (BTW, under
normal circumstances will the SLD override the CLASS specified in the map
file?)
The '&style=' parameter makes no difference whether it is present or not.
Does Mapserver have a debug mode where I could trace what is going on
internally?
Still stumped,
Rod.
-----Original Message-----
From: Bart van den Eijnden [mailto:bartvde at xs4all.nl]
Sent: Thursday, April 28, 2005 1:26 PM
To: Rod Suddaby; MAPSERVER-USERS at lists.umn.edu
Subject: Re: [UMN_MAPSERVER-USERS] Trouble getting SLD working
Hi Rod,
I can't see anything obvious wrong with what you are doing.
A few questions:
-is your WMS GetCapabilities working?
-does the LAYER work without an SLD, ie when you specify a CLASS?
-does it work if you leave out the style parameter in the request?
-your WMS request is not a full WMS request, it should contain a BBOX,
WIDTH, HEIGHT and SRS (among others). But Mapserver seems to be leniant
towards this and probably uses MAP file values.
Best regards,
Bart
On Thu, 28 Apr 2005 14:00:44 -0500, Rod Suddaby <rsuddaby at NRCAN.GC.CA>
wrote:
> Hi List:
> I'm a newbie to SLD and I've been trying to figure out why my build of
> mapserver will not apply the styles. I've created the following SLD xml
> file:
> [test_sld.xml]
> <StyledLayerDescriptor version="1.0.0" xmlns="http://www.opengis.net/sld"
> xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/
> ogc" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.
> org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://www.opengis.net/sld
> http://schemas.opengeospatial.net/sld/1.0.0/StyledLayerDescriptor.xsd">
> <NamedLayer>
> <Name>provinces</Name>
> <UserStyle>
> <Name>myStyle</Name>
> <FeatureTypeStyle>
> <Rule>
> <PolygonSymbolizer>
> <Fill>
> <CssParameter name="fill">#00ff00</CssParameter>
> </Fill>
> <Stroke>
> <CssParameter name="stroke">#0000ff</CssParameter>
> <CssParameter name="stroke-width">3</CssParameter>
> </Stroke>
> </PolygonSymbolizer>
> </Rule>
> </FeatureTypeStyle>
> </UserStyle>
> </NamedLayer>
> </StyledLayerDescriptor>
> The layer block of my mapfile is:
> LAYER
> NAME provinces
> DATA prov_prj
> PROJECTION
> "init=epsg:42304"
> END
> UNITS METERS
> TYPE POLYGON
> STATUS ON
> # CLASS
> # COLOR 255 0 0
> # OUTLINECOLOR 0 0 255
> # END
> END
> I've sent the following request to the mapserver:
> http://localhost/cgi-bin/mapserv?map=prov.map&version=1.1.
1&request=getMap&layers=provinces&styles=&sld=http://localhost/test_sld.xml
> ... and all I get is a blank image. Checking the apache access_log shows
> no
> hit for the 'test_sld.xml' file. It seems that mapserver is simply
> ignoring
> the sld parameter.
> I've also tried putting the "wms_sld_url" tag in the layer metadata,
> tried
> the "wms_sld_body" tag, and tried feeding the xml directly using the
> sld_body parameter -- same result
> Heres the output of mapserv -v:
> %dragon>./mapserv -v
> MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBNP
> SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=TIFF INPUT=EPPL7
> INPUT=POSTGIS
> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> O.S. Is Suse Linux 9.1
> Can anyone see if I'm missing something here?
> Also, are there any other resources available regarding SLD other than
> the
> spec and the HOWTO docs?
> Thanks,
> Rod.
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
