Trouble getting SLD working
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Fri Apr 29 18:26:57 EDT 2005
Rod,
1./ does the SLD indeed reside at http://localhost/test_sld.xml ?
2./ in your GetMap request, have you tried
"...styles=myStyle&sld=http://localhost/test_sld.xml..." (note it should
be "styles=", not "style=" ?
3./ Try inserting this element in the UserStyle element (after the
"Name" element)
<IsDefault>1</IsDefault>
..Tom
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Suddaby, Rod
> Sent: Thursday, 28 April, 2005 18:05
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Trouble getting SLD working
> Hi Bart,
> Yes, Mapserver operates fine with the exception of the SLD. The
> GetCapabilities responds with (with respect to SLD):
> <UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1"
> RemoteWFS="0"/> and the 'request=getStyles' request reports back fine
> as well (indicating the styles I set in the CLASS block).
> Using the CLASS block without the SLD works as expected, too.
> (BTW, under normal circumstances will the SLD override the
> CLASS specified in the map
> file?)
> The '&style=' parameter makes no difference whether it is
> present or not.
> Does Mapserver have a debug mode where I could trace what is
> going on internally?
> Still stumped,
> Rod.
> From: Bart van den Eijnden [mailto:bartvde at xs4all.nl]
> Sent: Thursday, April 28, 2005 1:26 PM
> To: Rod Suddaby; MAPSERVER-USERS at lists.umn.edu
> Hi Rod,
> I can't see anything obvious wrong with what you are doing.
> A few questions:
> -is your WMS GetCapabilities working?
> -does the LAYER work without an SLD, ie when you specify a CLASS?
> -does it work if you leave out the style parameter in the request?
> -your WMS request is not a full WMS request, it should
> contain a BBOX, WIDTH, HEIGHT and SRS (among others). But
> Mapserver seems to be leniant towards this and probably uses
> MAP file values.
> Best regards,
> Bart
> On Thu, 28 Apr 2005 14:00:44 -0500, Rod Suddaby <rsuddaby at NRCAN.GC.CA>
> wrote:
> > Hi List:
> > I'm a newbie to SLD and I've been trying to figure out why
> my build of
> > mapserver will not apply the styles. I've created the following SLD
> > xml
> > file:
> > [test_sld.xml]
> > <StyledLayerDescriptor version="1.0.0"
> > xmlns="http://www.opengis.net/sld"
> > xmlns:gml="http://www.opengis.net/gml"
> xmlns:ogc="http://www.opengis.net/
> > ogc" xmlns:xlink="http://www.w3.org/1999/xlink"
> xmlns:xsi="http://www.w3.
> > org/2001/XMLSchema-instance"
> > xsi:schemaLocation="http://www.opengis.net/sld
> http://schemas.opengeospatial.net/sld/1.0.0/StyledLayerDescrip
> tor.xsd">
> > <NamedLayer>
> > <Name>provinces</Name>
> > <UserStyle>
> > <Name>myStyle</Name>
> > <FeatureTypeStyle>
> > <Rule>
> > <PolygonSymbolizer>
> > <Fill>
> > <CssParameter name="fill">#00ff00</CssParameter>
> > </Fill>
> > <Stroke>
> > <CssParameter name="stroke">#0000ff</CssParameter>
> > <CssParameter name="stroke-width">3</CssParameter>
> > </Stroke>
> > </PolygonSymbolizer>
> > </Rule>
> > </FeatureTypeStyle>
> > </UserStyle>
> > </NamedLayer>
> > </StyledLayerDescriptor>
> > The layer block of my mapfile is:
> > LAYER
> > NAME provinces
> > DATA prov_prj
> > PROJECTION
> > "init=epsg:42304"
> > END
> > UNITS METERS
> > TYPE POLYGON
> > STATUS ON
> > # CLASS
> > # COLOR 255 0 0
> > # OUTLINECOLOR 0 0 255
> > # END
> > END
> > I've sent the following request to the mapserver:
> > http://localhost/cgi-bin/mapserv?map=prov.map&version=1.1.
> 1&request=getMap&layers=provinces&styles=&sld=http://localhost
> /test_sld.xml
> > ... and all I get is a blank image. Checking the apache access_log
> > shows no hit for the 'test_sld.xml' file. It seems that
> mapserver is
> > simply ignoring
> > the sld parameter.
> > I've also tried putting the "wms_sld_url" tag in the layer metadata,
> > tried the "wms_sld_body" tag, and tried feeding the xml directly
> > using the sld_body parameter -- same result
> > Heres the output of mapserv -v:
> > %dragon>./mapserv -v
> > MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBNP
> > SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> > SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> INPUT=TIFF
> > INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> > O.S. Is Suse Linux 9.1
> > Can anyone see if I'm missing something here?
> > Also, are there any other resources available regarding SLD
> other than
> > the spec and the HOWTO docs?
> > Thanks,
> > Rod.
> Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
