Tigerline data Imported to postgis and TEXT LABEL
William E Reid wer at CSTONE.NET
Tue Aug 2 11:49:29 PDT 2005
Greetings,
GDAL 1.2.1.0, released 2004/06/23
MapServer version 4.2.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7 INPUT=POSTGIS
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
PostgreSQL 7.4.6
I have noticed that ogr2ogr will import tigerline data using 'character'
types for some of the columns.
When doing normal selects (ex: where fename = 'teststreet')  I have two
choices:
where fename like 'teststreet%'
or
where trim(fename) = 'teststreet'.
Same goes for toaddr, fraddr, fedirp etc... Basically, anywhere I would
  want to see varchar(X) used, character(x) is used so trim() or % are
needed.
Mapscript will gladly display TEXT defined in my LABEL object, but it
does not trim the spaces (I am assuming because postgres treats
characters as (X length) strings without termination.
So I end up with labels that take up a lot of real estate especially
when displaying [toaddr]-[fraddr] as an example each being defined as
character(11) (right justified?!).
I can modify my columns and fix the problem (create column with new
type,copy data, move column, remove column....), but I was really hoping
to stay with generic tigerline data and whatever ogr wants it to be when
converted to postgis.  I am trying to cut back on the already large task
of updating/creating/indexing what I consider to be large amounts of data.
Some of this question belongs to ogr2ogr but the remainder (displaying
of labels) I wander about in mapserver.  Any little tidbits of thought
out there for my TEXT field and dealing with extra spaces returned from
postgis/ogr2ogr?
It could also be done efficiently through postgres with a cast, but as I
watch the statements coming from mapserver (and learn a bunch too), I
would not begin to want to throw and extra implicit cast in there.  Also
I didn't really want to add a regex for each TEXT label.
Do most of you guys (in the states) end up using Tigerline data or do
you get it somewhere else?  Do you roll your own tables for everything
anyway?
Thanks for all the Maps.  I dig it.  Mapserver has been a  really useful
tool for us.
-=Bill
More information about the MapServer-users mailing list
