Phpmapscript.dll
vincent.dacol
vincent.dacol at LAPOSTE.NET
Wed Aug 3 05:37:08 EDT 2005
I have put in php.ini:
The answers are bottom your questions.
> What exactly did you put in php.ini? What do you search for
in the phpinfo page, Mapscript?
extention=phpmapscript_46.dll
> Are there no errors reported by PHP with loading the
extension?
There are no error reported by php
Can all the dependent dll's be found?
this is the question ;) I don't no who're dependent dll, so I
have put a lot of them in my "ext" folder.
I'm under IIS (sorry, but I don't have the choice, and php5).
php5 work fine, IIS work has he can ;) (fine in fact)
My onlyest probleme is that I must use mapscript fonction, and
the extention doesn't appear when I do a phpinfo(), and IIS
could't use dl fonction :(((
Thanks for the help,
Best regards,
Vincent
> Best regards,
> Bart
> Bart van den Eijnden
> Syncera IT Solutions
> Postbus 270
> 2600 AG DELFT
> tel.nr.: 015-7512436
> email: BEN at Syncera-ITSolutions.nl
> >>> "vincent.dacol" <vincent.dacol at laposte.net> 08/03/05
11:27 AM >>>
> Hi Bart,
> I have put the extention in php.ini.
> I couldn't do a dl in a script.
> Best regards,
> Vincent
> > Hi,
> > did you a do a dl of the Mapscript extension before calling
> phpinfo? Or did you put the extension in php.ini to load by
> default?
> > Best regards,
> > Bart
> > Postbus 270
> > 2600 AG DELFT
> > >>> "vincent.dacol" <vincent.dacol at LAPOSTE.NET> 08/03/05
> 10:30 AM >>>
> > Hello everyone,
> > I have a little strange probleme.
> > I want to use phpmapscript.dll in my php installation. I have
> > put the dll in the correct folder (ext) and my php.ini is
> > correctly configured.
> > But when I make a phpinfo(), phpmapscript doesn't appeart on
> > the screen.
> > Anybody have had this problem? And how is it possible to
> > active this extention?
> > I only want to use this extention, not mapserver cgi.
> > Have a nice day,
> > Vincent
> > Accédez au courrier électronique de La Poste :
> www.laposte.net ;
> > 3615 LAPOSTENET (0,34/mn) ; tél : 08 92 68 13 50 (0,34/mn)
www.laposte.net ;
Accédez au courrier électronique de La Poste : www.laposte.net ;
