Phpmapscript.dll
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Wed Aug 3 05:57:01 EDT 2005
Normally it is called php_mapscript_46.dll (note the first underscore).
Where did you get the Mapscript binary from? For PHP5 it needs to be recompiled against PHP 5.
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> "vincent.dacol" <vincent.dacol at LAPOSTE.NET> 08/03/05 11:38 AM >>>
I have put in php.ini:
The answers are bottom your questions.
> What exactly did you put in php.ini? What do you search for
in the phpinfo page, Mapscript?
extention=phpmapscript_46.dll
> Are there no errors reported by PHP with loading the
extension?
There are no error reported by php
Can all the dependent dll's be found?
this is the question ;) I don't no who're dependent dll, so I
have put a lot of them in my "ext" folder.
I'm under IIS (sorry, but I don't have the choice, and php5).
php5 work fine, IIS work has he can ;) (fine in fact)
My onlyest probleme is that I must use mapscript fonction, and
the extention doesn't appear when I do a phpinfo(), and IIS
could't use dl fonction :(((
Thanks for the help,
Best regards,
Vincent
> Best regards,
> Bart
> Postbus 270
> 2600 AG DELFT
> >>> "vincent.dacol" <vincent.dacol at laposte.net> 08/03/05
11:27 AM >>>
> Hi Bart,
> I have put the extention in php.ini.
> I couldn't do a dl in a script.
> Best regards,
> Vincent
> > Hi,
> > did you a do a dl of the Mapscript extension before calling
> phpinfo? Or did you put the extension in php.ini to load by
> default?
> > Best regards,
> > Bart
> > Postbus 270
> > 2600 AG DELFT
> 10:30 AM >>>
> > Hello everyone,
> > I have a little strange probleme.
> > I want to use phpmapscript.dll in my php installation. I have
> > put the dll in the correct folder (ext) and my php.ini is
> > correctly configured.
> > But when I make a phpinfo(), phpmapscript doesn't appeart on
> > the screen.
> > Anybody have had this problem? And how is it possible to
> > active this extention?
> > I only want to use this extention, not mapserver cgi.
> > Have a nice day,
> > Vincent
> > Accédez au courrier électronique de La Poste :
> www.laposte.net ;
> > 3615 LAPOSTENET (0,34/mn) ; tél : 08 92 68 13 50 (0,34/mn)
www.laposte.net ;
Accédez au courrier électronique de La Poste : www.laposte.net ;
