quotes and apostrophes in dbf
Andreas Albarello
andreas.albarello at TERRITORIUMONLINE.COM
Thu Aug 4 13:53:50 EDT 2005
I noticed that dbf-records containing apostrophes or quotes in one of
their fields don't show up in the attribute query results when such a
field is referenced inside the expression.
For instance, a query like
'[ORT_NAME_I]' =~ /.*(A|a)(N|n)(D|d)(R|r).*/
produces the expected results except for the record where ORT_NAME_I is
Sant'Andrea, which doesn't show up due to the apostrophe (things behave
exactly the same on other dbf-data, using different queries and working
on different machines, when there's char #34 or #39 around).
I guess that things go wrong somewhere inside the parser which is called
from msEvalExpression. In fact, what we probably need to do is to escape
any quote and apostrophe in a record as things are ok when I surround
[ORT_NAME_I] in the example above with quotes instead of apostrophes,
but that, viceversa, hides any record containing a quote. Of course, I
may be wrong as well.
Has anybody else experienced this behavior too?
Best regards,
Andreas Albarello
Territorium Online Srl/GmbH
andreas.albarello at territoriumonline.com
www.territoriumonline.com
