wfs server problem
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Thu Aug 25 10:53:08 EDT 2005
Yes, the same MAP file can serve both WMS and WFS.
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Mehdi Kiman <oubinny at HOTMAIL.COM> 08/25/05 4:51 pm >>>
I can have the same MapFile for using both WFS and WFS serveur ?
>From: "Bart van den Eijnden" <BEN at Syncera-ITSolutions.NL>
>To: <oubinny at HOTMAIL.COM>,<MAPSERVER-USERS at LISTS.UMN.EDU>
>Subject: Re: [UMN_MAPSERVER-USERS] wfs server problem
>Date: Thu, 25 Aug 2005 16:34:53 +0200
>When you are doing a GetCapabilities, what is your URL?
>Do you add &service=WFS&request=GetCapabilities&version=1.0.0
>otherwise probably the default is the WMS capabilities and you miss
>"wms_title" METADATA for that. If you want to be shorter, use the more
>general ows_title and leave out wfs_title and wms_title.
>Best regards,
>Bart
>Postbus 270
>2600 AG DELFT
> >>> Mehdi Kiman <oubinny at HOTMAIL.COM> 08/25/05 4:29 pm >>>
>Hi,
>I have a problem with my WFS server, i tried to configure it.
>My MapFile is correct :
>MAP
>NAME "Pays_nee_de_la_mer"
>DEBUG on
>SIZE 600 400
>STATUS ON
>EXTENT 310559.98 2147175.0 335547.03 2176659.97
>FONTSET "../data/fonts.txt"
>UNITS METERS
>SHAPEPATH "../data/data_map/"
>WEB
> IMAGEPATH 'C:/tmp/ms_tmp/'
> IMAGEURL '/ms_tmp/'
> METADATA
> "wfs_title" "wfs Pays Ne de La Mer"
> "wfs_onlineresource"
>"http://emir:8080/cgi-bin/mywfs.exe?config_wfs.map&"
> "wfs_srs" "epsg:27582"
> "wfs_feature_info_mime_type" "text/html"
> END
>END
>LAYER
> CONNECTIONTYPE OGR
> CONNECTION "../data/data_map/Parcelles.TAB"
> NAME "Parcelles"
> TYPE POLYGON
> STATUS ON
> #STYLEITEM "AUTO"
> CLASS
> NAME "Parcelles"
> TEMPLATE "ttt.html"
> STYLE
> COLOR 255 255 0
> OUTLINECOLOR 0 0 2
> END
> END
> METADATA
> "wfs_title" "Parcelles"
> END
> PROJECTION
> "init=epsg:27582"
> END
>END
>And when i make a GetCapabilities, i have this kind of error for each layer
><!-- WARNING: Mandatory metadata '..._title' was missing in this context.
>What's wrong with my server ?
>Thanks
>Mehdi
