wfs server problem
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Thu Aug 25 11:07:05 EDT 2005
You should add DUMP TRUE to your LAYER.
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> "Mehdi Kiman" <oubinny at hotmail.com> 08/25/05 5:04 pm >>>
Now getCapabilities is ok. But when i make a
http://emir:8080/cgi-bin/mywfs.exe?&SERVICE=WFS&REQUEST=getfeature&VERSION=1.0.0&TYPENAME=Parcelles
The WFS server output is
<ServiceException>msWFSGetFeature(): WFS server error. TYPENAME 'Parcelles'
doesn't exist in this server. Please check the capabilities and reformulate
your request.</ServiceException>
I'm so surprised beacause my getCapabilities return is correct.
>From: "Bart van den Eijnden" <BEN at Syncera-ITSolutions.NL>
>To: <oubinny at HOTMAIL.COM>
>CC: <MAPSERVER-USERS at LISTS.UMN.EDU>
>Subject: Re: [UMN_MAPSERVER-USERS] wfs server problem
>Date: Thu, 25 Aug 2005 16:53:08 +0200
>Yes, the same MAP file can serve both WMS and WFS.
>Bart
>Postbus 270
>2600 AG DELFT
> >>> Mehdi Kiman <oubinny at HOTMAIL.COM> 08/25/05 4:51 pm >>>
>I can have the same MapFile for using both WFS and WFS serveur ?
> >To: <oubinny at HOTMAIL.COM>,<MAPSERVER-USERS at LISTS.UMN.EDU>
> >Date: Thu, 25 Aug 2005 16:34:53 +0200
> >When you are doing a GetCapabilities, what is your URL?
> >Do you add &service=WFS&request=GetCapabilities&version=1.0.0
> >otherwise probably the default is the WMS capabilities and you miss
> >"wms_title" METADATA for that. If you want to be shorter, use the more
> >general ows_title and leave out wfs_title and wms_title.
> >Best regards,
> >Bart
> >Postbus 270
> >2600 AG DELFT
> > >>> Mehdi Kiman <oubinny at HOTMAIL.COM> 08/25/05 4:29 pm >>>
> >Hi,
> >I have a problem with my WFS server, i tried to configure it.
> >My MapFile is correct :
> >MAP
> >NAME "Pays_nee_de_la_mer"
> >DEBUG on
> >SIZE 600 400
> >STATUS ON
> >EXTENT 310559.98 2147175.0 335547.03 2176659.97
> >FONTSET "../data/fonts.txt"
> >UNITS METERS
> >SHAPEPATH "../data/data_map/"
> >WEB
> > IMAGEPATH 'C:/tmp/ms_tmp/'
> > IMAGEURL '/ms_tmp/'
> > METADATA
> > "wfs_title" "wfs Pays Ne de La Mer"
> > "wfs_onlineresource"
> >"http://emir:8080/cgi-bin/mywfs.exe?config_wfs.map&"
> > "wfs_srs" "epsg:27582"
> > "wfs_feature_info_mime_type" "text/html"
> > END
> >END
> >LAYER
> > CONNECTIONTYPE OGR
> > CONNECTION "../data/data_map/Parcelles.TAB"
> > NAME "Parcelles"
> > TYPE POLYGON
> > STATUS ON
> > #STYLEITEM "AUTO"
> > CLASS
> > NAME "Parcelles"
> > TEMPLATE "ttt.html"
> > STYLE
> > COLOR 255 255 0
> > OUTLINECOLOR 0 0 2
> > END
> > END
> > METADATA
> > "wfs_title" "Parcelles"
> > END
> > PROJECTION
> > "init=epsg:27582"
> > END
> >END
> >And when i make a GetCapabilities, i have this kind of error for each
>layer
> ><!-- WARNING: Mandatory metadata '..._title' was missing in this context.
> >What's wrong with my server ?
> >Thanks
> >Mehdi
