msautotest/regression testing question
Gambin Dejan
Dejan.Gambin at PULA.HR
Mon Aug 29 05:54:03 EDT 2005
I have successfully run siege without the ssl support. Thanks
regards
dejan
-----Original Message-----
From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
Sent: Wednesday, August 24, 2005 3:06 PM
To: Gambin Dejan
Subject: Re: [UMN_MAPSERVER-USERS] msautotest/regression testing
question
I highly recommend Siege from
http://www.joedog.org/
I have used this extensively for testing mapserver and mapfiles with
good results. It is easy to set up can use. I use a perl script to
generate urls for it, but I think there is a tool the will scan you web
logs and convert them into input files for Siege depending on how your
application generates urls.
-Steve W.
Gambin Dejan wrote:
> Hi,
> I suppose this question is mostly intended to Frank but maybe someone
> else can answer too.
> I would like how this thing is working and can it be used (at least
> partially) to help me implement some kind of benchmarking that would
> simulate a number of simultaneous visitors doing the map actions
> (zooming, panning, activating/deactivating layers, querying, etc.).
> This would help me decide on hardware requirements and especially the
> Internet bandwidth that I need to lease form my ISP.
> thanks very much
> regards
> dejan
