Problem with Perl script and image maps
Robert Parsons
rparsons at TAPPUBLISHING.COM
Mon Aug 29 13:38:01 EDT 2005
Can anyone offer any insight for this problem? I get "Segmentation Fault"
any time I attempt to call $map->draw() for any map that is set to output
via the "imagemap" driver. It's quite easy for me to reproduce and it even
happens when simply opening a .map file from within a perl script. For
example, this simple script throw a Seg Fault during the draw().
#!/usr/bin/perl
use mapscript;
my $msmap = mapscript::mapObj->new('test.map');
my $image=$msmap->draw();
$image->save('test');
Here's the test.map file:
MAP
EXTENT -14023070.10627 1859777.927636 -7135266.299414 7255753.260196
IMAGECOLOR 0 0 0
IMAGETYPE imagemap
SHAPEPATH "/wxhub/common/shapefiles"
SIZE 868 680
STATUS ON
UNITS METERS
NAME "TEST"
OUTPUTFORMAT
NAME "imagemap"
MIMETYPE "text/html"
DRIVER "imagemap"
END
PROJECTION
"proj=merc"
"lat_0=0"
"lon_0=0"
"datum=WGS84"
END
WEB
IMAGEPATH ""
IMAGEURL ""
METADATA
END
QUERYFORMAT text/html
END
LAYER
DATA "statesp020"
METADATA
END
NAME "mylayer"
PROJECTION
"proj=latlong"
END
SIZEUNITS PIXELS
STATUS ON
TOLERANCEUNITS PIXELS
TYPE POLYGON
UNITS METERS
CLASS
METADATA
END
STYLE
ANGLE 360
COLOR 255 255 255
SIZE 1
SYMBOL 0
END
END
END
END
The same code will work fine if I change the .map file to output to a GIF
instead of an imagemap.
Any help would be appreciated.
- R. Parsons
