Rendering and EPSG problem?
Frank Warmerdam
fwarmerdam at GMAIL.COM
Tue Aug 30 12:34:31 EDT 2005
On 8/29/05, Chau,Philip [PYR] <Philip.Chau at ec.gc.ca> wrote:
> Hi there,
> I'm getting an error when I add a Demis layer with a EPSG 4326 to a map with
> layers in EPSG 42102
> The error is :
> "ERROR Rendering map image: a fatal error occurred drawing the map"
> However if I remove the Demis layer it renders fine.
> I have tried to just add the Demis layer in Map mode by itself and it
> renders fine.
> Is there a list of things which I can try?
Phil,
I am suspecting that MapServer is having a hard time using
EPSG:42102. Are you use it is listed in your epsg lookup file
for PROJ.4? In cases where no reprojection is going on,
declaring it might have cause no problem.
I tried looking up 42102 with GDAL's EPSG lookup services
and found it was a cubewerx addition for BC Albers but for
some reason I had to comment out this particular coordinate
system because it was causing problems. Perhaps this somehow
relates to your problem.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
