SLD, fonts and Mapserver
Gustavo Henrique Sberze Ribas
gribas at CPQD.COM.BR
Tue Dec 6 07:51:33 EST 2005
I wonder what I'm doing wrong here, I'm trying to format the layer's
font with SLD using the <sld:font> tag but if I set the style or weight
to normal Mapserver ignores everything and use the default bitmap font.
I.e., if the following tag is present in the SLD
<sld:CssParameter name="font-style">normal</sld:CssParameter>
then mapserver will use the default font and ignore the other
attributes such as size and rotation. This happens with versions 4.4
and 4.6 (ms4w).
I've build a simple test page to show the problem:
http://www.cpqd.com.br/mrni-geo/sld_test.html
Any ideas? From the how-to:
"When a Font Style or a Font Weight is set to normal in an SLD, it is also
ignored in building the name. For example, if there is an SLD with a Font
Family of arial, a Font Style of normal and a Font weight equals to bold,
the resulting MapServer font name is arial-bold."
thanks,
