SLD, fonts and Mapserver
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Tue Dec 6 10:38:31 EST 2005
Hi There,
I have added a bug on it
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1552 and corrected it.
It will be available for the 4.8 relase. (You can get it from CVS too).
The documentation was correct but the code actually doing it was
missing. It is one of those rare momenets where the docs are more
uptodate that the code.
I hace also noted when verifying this bug that there was a mistake in
the order in whic the fint paramaters are used to build the font name. I
have entered a bug on it (Bug 1553)
If the sld you are using contain "normal" a quick around before you get
the 4.8 would be to define your fonts in fonts.txt using the word
normal. For example :
times-bold-normal timesbd.ttf
One last thing, thanks for reporting it with clear examples.
Later,
Gustavo Henrique Sberze Ribas wrote:
> Hi,
> I wonder what I'm doing wrong here, I'm trying to format the layer's
> font with SLD using the <sld:font> tag but if I set the style or
weight to normal Mapserver ignores everything and use the default bitmap
font.
> I.e., if the following tag is present in the SLD
> <sld:CssParameter name="font-style">normal</sld:CssParameter>
> then mapserver will use the default font and ignore the other
attributes such as size and rotation. This happens with versions 4.4
> and 4.6 (ms4w).
> I've build a simple test page to show the problem:
> http://www.cpqd.com.br/mrni-geo/sld_test.html
> Any ideas? From the how-to:
> "When a Font Style or a Font Weight is set to normal in an SLD, it is
also ignored in building the name. For example, if there is an SLD with
a Font Family of arial, a Font Style of normal and a Font weight equals
to bold, the resulting MapServer font name is arial-bold."
> thanks,
Assefa Yewondwossen Software Analyst
Email: assefa at dmsolutions.ca http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
