Yewondwossen Assefa wrote: > If the sld you are using contain "normal" a quick around > before you get the 4.8 would be to define your fonts in > fonts.txt using the word normal. For example : > times-bold-normal timesbd.ttf Many thanks Assefa, it worked flawlessly. I'm looking forward to the next release. regards, Gustavo
