Querying and labeling a WFS layer in Ma pserver WFS client
frequens
frequens at GMAIL.COM
Mon Dec 12 07:07:54 EST 2005
On 12/12/05, Eijnden, B. van den (Bart) <b.vdeijnden at agi.rws.minvenw.nl> wrote:
> Do you have DUMP TRUE set as well as a TEMPLATE defined on your LAYER?
> How are you querying your layer? Through Mapserver CGI interface or through WMS GetFeatureInfo? Can you give us an example request and response?
> Best regards,
> Bart
DUMP TRUE is there, and a 'dummy' TEMPLATE also, TOLERANCE set to 10
I tried two much simpler examples in php-mapscript now:
$queryObj = $map->queryByPoint( $ptClicked,MS_SINGLE,-1 );
produces:
Warning: [MapServer Error]: msQueryByPoint(): No matching record(s) found. in...
while
$queryObj = $resultlayer->getWMSFeatureInfoURL($georef_x, $georef_y,
100, "MIME");
produces:
Warning: [MapServer Error]: msBuildWMSLayerURL(): Call supported only
for CONNECTIONTYPE WMS....
which leads me to a fundamental question whether Mapserver (or
php-mapscript) supports querying WFS layers at all?
BR
frequens
