wcs and ecw
Miguel Ángel
techdlists at YAHOO.ES
Wed Dec 14 13:45:25 EST 2005
I trying to get mapserver to serve ecw and geotiff rasters through the wcs
service, using mapserver 4.6.2, gdal 1.3.1 (compiled with the ecw and
geotiff option, read and write permission), ecwsdk-3.1.25Jan05-linux and
libgeotiff-1.2.2.
It works fine with the geotiff files, but when I request an ecw raster I get
a corrupt file from the server.
Has anybody had the same problem?
thanks in advance,
Miguel Ángel
compilation options:
** GDAL:
./configure --with-libtiff=yes --with-geotiff=yes
--with-pg=/usr/local/pgsql/bin/pg_config
--with-geos=/usr/local/bin/geos-config
--with-ecw=../ecwsdk-3.1.25Jan05-linux --with-jasper=yes --with-python
** MAPSERVER):
./configure --with-proj=/usr/local/src/proj-4.4.9
--with-freetype=/usr/bin/freetype-config
--with-ogr=/usr/local/bin/gdal-config --with-gdal=/usr/local/bin/gdal-config
--with-postgis=/usr/local/pgsql/bin/pg_config --with-wfs --with-wms
--with-wmsclient --with-wfsclient --with-wcs
--with-curl-config=/usr/bin/curl-config --with-httpd=/usr/sbin/httpd2-worker
--with-geos=/usr/local/bin/geos-config --with-threads
this is the .map file:
MAP
NAME XXXXX
STATUS ON
IMAGETYPE PNG
SIZE 1024 768
IMAGECOLOR 255 255 255
SHAPEPATH "."
EXTENT 736578 4429321 771455 4454233
UNITS METERS
PROJECTION
"init=epsg:23030"
END
WEB
IMAGEPATH "/tmp"
IMAGEURL "http://localhost/tmp/"
METADATA
OWS_TITLE "XXXXX"
OWS_LABEL "XXXXX"
OWS_ONLINERESOURCE "XXXXXXX"
OWS_KEYWORDLIST "WMS,WCS"
OWS_SRS "EPSG:23030"
OWS_SCHEMAS_LOCATION "http://ogc.dmsolutions.ca"
OWS_NAMESPACE_PREFIX "XXXX"
OWS_NAMESPACE_URI "XXXXXXXXXXXX"
END
END
OUTPUTFORMAT
NAME GEOTIFF
DRIVER "GDAL/GTiff"
MIMETYPE "image/tif"
IMAGEMODE "BYTE"
EXTENSION "tif"
END
OUTPUTFORMAT
NAME ECW
DRIVER "GDAL/ECW"
MIMETYPE "image/ecw"
IMAGEMODE "BYTE"
EXTENSION "ecw"
END
# qb_h61666.tif
LAYER
GROUP QUICKBIRD
NAME "XXXXX"
TYPE RASTER
STATUS ON
DUMP TRUE
PROCESSING "SCALE=AUTO"
PROCESSING "BANDS=1,2,3"
DATA "Quickbird/XXXXXX.tif"
MAXSCALE 500000
METADATA
OWS_TITLE "XXXXX"
OWS_LABEL "XXXXX"
wcs_resolution "0.7 -0.7"
wcs_formats "GEOTIFF"
wcs_nativeformat "raw_binary"
wcs_rangeset_axes "bands"
wcs_rangeset_label "bands"
wcs_rangeset_name "bands"
wcs_bandcount "3"
END
END
LAYER
GROUP ECW
NAME "XXXX"
STATUS ON
DATA "Ortofotos/XXXX.ecw"
DUMP TRUE
TYPE RASTER
METADATA
OWS_TITLE "XXXXXX"
OWS_LABEL "XXXXXXX"
wcs_resolution "0.5 -0.5"
wcs_formats "ECW"
wcs_bandcount "3"
END
END
END
