starting-problem: doesn't show the content
Martin Vigerske
martin at VIGERSKE.DE
Sat Dec 17 11:16:11 EST 2005
Ah, of course, the status. Now it works. :-)
Well, thank you very much.
Greetings,
Martin Vigerske
Wim Blanken schrieb:
> Hello Martin,
> Mapserver does not know you want to view the US state boundaries layer.
> Two solutions:
> 1. Give the US State boundaries layer the STATUS DEFAULT instead of ON
> 2. Include the layername with the layers statement.
> http://localhost/cgi-bin/mapserv.exe?map=usa1.map&mode=map&layers=US
> state boundaries. It's easier by the way (for a start) that you do not
> include spaces in the name of the layer.
> Regards,
> Wim Blanken
> The Netherlands
> ----- Original Message ----- From: "Martin Vigerske" <martin at VIGERSKE.DE>
> To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> Sent: Saturday, December 17, 2005 1:51 PM
> Subject: [UMN_MAPSERVER-USERS] starting-problem: doesn't show the content
>> Hi,
>> I am new to the MapServer and tried a demo-mapfile, but it shows me
>> no Shapefile and no Tiff.
>> I installed the win-version ms4w (4.6). The demo-mapfile (usa1.map)
>> came into the directory c:\ms4w\Apache\cgi-bin\, the shapefile
>> "statesp020" to my own directory c:\ms4w\usr\shapes\. The only thing
>> I changed in the demo-map was the SHAPEPATH, from
>> "/var/www/html/data" to "c:\ms4w\usr\shapes\" (and the imagepath, but
>> that should not be the problem). When I start mapserv with
>> "http://localhost/cgi-bin/mapserv.exe?map=usa1.map&mode=map", I get a
>> grey rectangle and the text-layer "Made with Mapserver". The
>> Mapserver works but it doesn't show me the shapefile.
>> The same with the example usa3.map which should render a RASTER. I
>> change the data-path to the path of the tif, but it doesn't show up.
>> I tried to copy shape and tif directly into the cgi-bin-directory,
>> where the .map is, but no difference.
>> I guess mapserver can't find the data.
>> The log-file isn't very informative:
>> "Sat Dec 17 13:43:24 2005,3728,127.0.0.1,USA1,3,-8000000.000000
>> -3162500.000000 5000000.000000 4962500.000000,-1.000000
>> -1.000000,,normal execution"
>> Any ideas?
>> Greetings and thanks,
>> Martin Vigerske
>> --- my usa1.map:
>> MAP
>> NAME USA1
>> STATUS ON
>> SIZE 800 500
>> IMAGETYPE PNG
>> IMAGECOLOR 240 240 240
>> SHAPEPATH "c:\ms4w\usr\shapes\"
>> EXTENT -8000000 300000 5000000 1500000
>> UNITS METERS
>> PROJECTION
>> "proj=lcc" "lat_1=32" "lat_2=44" "lat_0=38" "lon_0=-100"
>> "x_0=0" "y_0=0" "ellps=GRS80" "datum=NAD83"
>> END
>> WEB
>> IMAGEPATH "c:\ms4w\usr\tmp\"
>> IMAGEURL "\usr\tmp\"
>> END
>> LAYER
>> NAME "US state boundaries"
>> TYPE POLYGON
>> STATUS ON
>> DATA "statesp020"
>> PROJECTION
>> "proj=latlong"
>> "ellps=GRS80"
>> "datum=NAD83"
>> END
>> CLASS
>> NAME "US states"
>> OUTLINECOLOR 60 60 60
>> COLOR 255 255 0
>> SYMBOL 0
>> END
>> END
>> LAYER
>> NAME "credits"
>> STATUS DEFAULT
>> TRANSFORM FALSE
>> TYPE ANNOTATION
>> FEATURE
>> POINTS
>> 10 480
>> END
>> TEXT 'Made with Mapserver.'
>> END
>> CLASS
>> LABEL
>> TYPE BITMAP
>> POSITION CR
>> COLOR 0 0 0
>> END
>> END
>> END
>> END
