HELP-Virtual Spatial Data
Frank Fica
simbiotico at HOTMAIL.COM
Mon Dec 19 00:51:16 EST 2005
Hello,
I'm testing an OGR ODBC connection to my postgresql database to map Lat and Lon columns, but
when I test my file.map I only get a blank screen and no errors.
When I test with ogrinfo I get all the columns listed including the new POINT column with my
coordinates, works fine.
Here's my ovf file:
<OGRVRTDataSource>
<OGRVRTLayer name="sorento">
<SrcDataSource>ODBC:@PostgreSQL</SrcDataSource>
<SrcLayer>record</SrcLayer>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS>WGS84</LayerSRS>
<GeometryField encoding="PointFromColumns" x="Lat" y="Lon"/>
</OGRVRTLayer>
</OGRVRTDataSource>
Here's my file.map:
MAP
IMAGETYPE PNG
EXTENT -92.241493 13.738197 -88.223198 17.815220
SIZE 640 480
PROJECTION
"proj=latlong"
"ellps=WGS84"
"datum=WGS84"
END
SYMBOL
NAME 'circle'
TYPE ELLIPSE
FILLED TRUE
POINTS
1 1
END
END
LAYER
NAME "sorento"
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "virtual.ovf" # the name and path to the virtual.ovf file, relative to shapepath may
work?
DATA "sorento" # the name of the OGRVrtLayer
STATUS DEFAULT
CLASS
SYMBOL "circle"
SIZE 6
COLOR 255 0 0
END
END
END
