HELP-Virtual Spatial Data
Simbiosis Amorpha
simbiotico at HOTMAIL.COM
Mon Dec 19 12:42:13 EST 2005
Thanks David,
I already switched my x,y and I still get a blank image. I'm accesing my map
with:
http://maps.localizame.net/cgi-bin/mapserv?map=/var/www/html/starfinder/star.map&mode=map
If I do a ogrinfo virtual.ovf starfinder I get this:
OGRFeature(sorento):27
UserID (String) = Sorento
Lat (String) = 14.6538233333333
Lon (String) = -90.5103
Status (String) = A
E/W (String) = W
Date (String) = 051218
TimeStamp (String) = 213533
N/S (String) = N
Speed (String) = 0.00
Course (String) = 90.73
Geofence (String) = (null)
PowerOff (String) = (null)
Panic (String) = (null)
Opto1 (String) = (null)
Opto2 (String) = (null)
Relay1 (String) = (null)
Relay2 (String) = (null)
Serial No (String) = (null)
Version (String) = (null)
Memory Size (String) = (null)
KeyNo (Integer) = 5767
POINT (-90.5103 14.6538233333333 0)
Best regards,
Frank
>From: "Fawcett, David" <David.Fawcett at pca.state.mn.us>
>To: "Frank Fica" <simbiotico at hotmail.com>,
><MAPSERVER-USERS at lists.umn.edu>
>Subject: RE: [UMN_MAPSERVER-USERS] HELP-Virtual Spatial Data
>Date: Mon, 19 Dec 2005 09:12:08 -0600
>Frank,
>Take a look at this line: <GeometryField
>encoding="PointFromColumns" x="Lat" y="Lon"/>
>I belive that you have your x/y columns switched. It should be that
>x=longitude and y=latitude.
>-----Original Message-----
>From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
>Behalf Of Frank Fica
>Sent: Sunday, December 18, 2005 11:51 PM
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: [UMN_MAPSERVER-USERS] HELP-Virtual Spatial Data
>Hello,
>I'm testing an OGR ODBC connection to my postgresql database to map Lat
>and Lon columns, but when I test my file.map I only get a blank screen
>and no errors. When I test with ogrinfo I get all the columns listed
>including the new POINT column with my coordinates, works fine.
>Here's my ovf file:
><OGRVRTDataSource>
> <OGRVRTLayer name="sorento">
> <SrcDataSource>ODBC:@PostgreSQL</SrcDataSource>
> <SrcLayer>record</SrcLayer>
> <GeometryType>wkbPoint</GeometryType>
> <LayerSRS>WGS84</LayerSRS>
> <GeometryField encoding="PointFromColumns" x="Lat" y="Lon"/>
> </OGRVRTLayer>
></OGRVRTDataSource>
>Here's my file.map:
>MAP
> IMAGETYPE PNG
> EXTENT -92.241493 13.738197 -88.223198 17.815220
> SIZE 640 480
> PROJECTION
> "proj=latlong"
> "ellps=WGS84"
> "datum=WGS84"
> END
> SYMBOL
> NAME 'circle'
> TYPE ELLIPSE
> FILLED TRUE
> POINTS
> 1 1
> END
> END
> LAYER
> NAME "sorento"
> TYPE POINT
> CONNECTIONTYPE OGR
> CONNECTION "virtual.ovf" # the name and path to the virtual.ovf
>file, relative to shapepath may work?
> DATA "sorento" # the name of the OGRVrtLayer
> STATUS DEFAULT
> CLASS
> SYMBOL "circle"
> SIZE 6
> COLOR 255 0 0
> END
> END
>END
