HELP-Virtual Spatial Data
Simbiosis Amorpha
simbiotico at HOTMAIL.COM
Mon Dec 19 12:33:29 EST 2005
Thanks for the fast response Artur,
I have tried modifying my map file but still get a blank image. I'm trying
to get my map with:
http://maps.localizame.net/cgi-bin/mapserv?map=/var/www/html/starfinder/star.map&mode=map
Best regards,
Frank
>From: Skalski Artur - askals <Artur.Skalski at ACXIOM.COM>
>Reply-To: Skalski Artur - askals <Artur.Skalski at ACXIOM.COM>
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: Re: [UMN_MAPSERVER-USERS] HELP-Virtual Spatial Data
>Date: Mon, 19 Dec 2005 09:17:53 +0100
>Try to modify your mapfile like this, I had the same problem and it helped:
>LAYER
> NAME "sorento"
> TYPE POINT
> CONNECTIONTYPE OGR
> CONNECTION "virtual.ovf" # the name and path to the virtual.ovf file,
>relative to shapepath may
>work?
> DATA "sorento" # the name of the OGRVrtLayer
> STATUS DEFAULT
> CLASS
> STYLE
> SYMBOL "circle"
> SIZE 6
> COLOR 255 0 0
> END
> END
>END
>regards
>Artur Skalski
>-----Original Message-----
>From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
>Behalf Of Frank Fica
>Sent: Monday, December 19, 2005 6:51 AM
>Subject: [UMN_MAPSERVER-USERS] HELP-Virtual Spatial Data
>Hello,
>I'm testing an OGR ODBC connection to my postgresql database to map Lat and
>Lon columns, but
>when I test my file.map I only get a blank screen and no errors.
>When I test with ogrinfo I get all the columns listed including the new
>POINT column with my
>coordinates, works fine.
>Here's my ovf file:
><OGRVRTDataSource>
> <OGRVRTLayer name="sorento">
> <SrcDataSource>ODBC:@PostgreSQL</SrcDataSource>
> <SrcLayer>record</SrcLayer>
> <GeometryType>wkbPoint</GeometryType>
> <LayerSRS>WGS84</LayerSRS>
> <GeometryField encoding="PointFromColumns" x="Lat" y="Lon"/>
> </OGRVRTLayer>
></OGRVRTDataSource>
>Here's my file.map:
>MAP
> IMAGETYPE PNG
> EXTENT -92.241493 13.738197 -88.223198 17.815220
> SIZE 640 480
> PROJECTION
> "proj=latlong"
> "ellps=WGS84"
> "datum=WGS84"
> END
> SYMBOL
> NAME 'circle'
> TYPE ELLIPSE
> FILLED TRUE
> POINTS
> 1 1
> END
> END
> LAYER
> NAME "sorento"
> TYPE POINT
> CONNECTIONTYPE OGR
>work?
> STATUS DEFAULT
> CLASS
> SYMBOL "circle"
> SIZE 6
> COLOR 255 0 0
> END
> END
>END
>The information contained in this communication is confidential, is
>intended only for the use of the recipient named above, and may be legally
>privileged.
>If the reader of this message is not the intended recipient, you are
>hereby notified that any dissemination, distribution or copying of this
>communication is strictly prohibited.
>If you have received this communication in error, please resend this
>communication to the sender and delete the original message or any copy
>of it from your computer system.
>Thank You.
