TIN (Triangular Irregular Network) files and MapServer
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Mon Dec 19 16:16:02 EST 2005
http://www.google.com/search?num=100&hl=en&lr=&newwindow=1&safe=off&q=tin+shapefile+convert&btnG=Search
G. Madrigal wrote:
> Quoting Paul Ramsey <pramsey at REFRACTIONS.NET>:
>>Chip,
>>TIN is a data structure, not a file type. Different GIS vendors
>>encode TIN data structures in file formats in different ways, just as
>>they encode simple feature data structures in file formats in
>>different ways. In general, Mapserver does not support any specific
>>TIN file types. As Gerry indicates in his email, if you convert your
>>TIN into a simple features structure (edges, or faces) in a format
>>Mapserver supports (Shape, PostGIS, etc) then everything procedes as
>>normal.
> How can I save or generate a shapefile from a TIN file (generated with ArcView
> 3.2)?
> Thanks,
